5ghz radio not showing
stein9700
Beginner
Beginner
I have WLC 2504 (8.3.143.0) in Brazil with 4 AIR-CAP2702E-Z-K9 connected to it.
The AP 5 ghz radio are enable but when i got to 802.11a/n/ac Radios nothing is listed. Right now the WLC Regulatory Domain is set for the US and I think that is the issue.
If i change the WLC to BR will this cause all of the AP's to reboot?
AP's:
AIR-CAP2702E-Z-K9 are Regulatory Domain for Brazil per this link
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
thanks
2 Accepted Solutions
Well you might have to reboot the WLC when you make the change in order for the new country code to take affect.
-Scott
I don’t call it cowboy... it’s break fix to me:)
-Scott
8 Replies 8
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
The radio has crashed.
Remote into the AP and post the complete output to the command "dir". There should be a file called "r1.core" or something. If this is present, and the date is recent, then this confirms the radio has crashed.
To fix this, reboot the AP. If the radio is still not working, remote into the AP again and delete the CAPWAP image and reboot. This will force the AP to load the "RCV" image.
Here is a dir from the AP, I don't see the r1.core.
Directory of flash:/
2 -rwx 285 Jan 1 1970 00:02:46 +00:00 info
3 -rwx 12335 Jan 26 2019 15:48:09 +00:00 event.log
39 drwx 0 Jan 1 1970 00:02:38 +00:00 ap3g2-rcvk9w8-mx
8 drwx 2496 Jan 26 2019 15:47:47 +00:00 ap3g2-k9w8-mx.153-3.JD16
4 -rwx 1919 Mar 1 1993 00:50:18 +00:00 private-config
7 -rwx 64 Jan 26 2019 15:48:07 +00:00 sensord_CSPRNG0
6 -rwx 146 Jan 28 2019 19:10:24 +00:00 capwap-saved-config-bak
247 -rwx 8706 Mar 1 1993 00:50:18 +00:00 config.txt
248 drwx 0 Mar 1 1993 00:15:39 +00:00 configs
72 -rwx 64 Jan 26 2019 15:48:07 +00:00 sensord_CSPRNG1
73 -rwx 146 Jan 26 2019 17:00:22 +00:00 capwap-saved-config
74 -rwx 371 Jan 26 2019 17:00:22 +00:00 env_vars
75 -rwx 13336 Jan 29 2019 15:41:56 +00:00 private-multiple-fs
Stein9700
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
You do have the country code for Brazil enable on the WLC correct?  Like you mentioned, you have US and that might be the issue.
-Scott
So will the AP's reboot if i change the country code? Trying to decide if I cowboy ninja this during the day or 15 minutes after everyone leaves.
thanks
-Scott
So i cowboy ninja the change and rebooted the WLC.
All radios are on!
-Scott
delete some odd reason i posted twice
Recognize Your Peers
