7500 flex dazed and confused message
George Wolf
Uhhuh. NMI received for unknown reason 2d.
Do you have a strange power saving mode enabled?
Dazed and confused, but trying to continue
I replaced the power supplies and hooked up console but see this message on the box.. TAC didn't want to replace it thinking it was a power issue but it isn't is there any setting or something Im missing on the 7500 WLC ?  this problem started out of the blue
Saurav Lodh
Level 7
Level 7
NMI ( non maskable interrupt) lets software reboot the device due to hardware failures like fan etc.
I had to replace the box, it failed and the tac couldn't diagnose it.  Since it's replacement I've never seen it happen again.  Thanks and just putting this out there should anyone else run into it.
G
