7925 phone delay
I am implementing a wireless LAN, Data and Voice vlans are broadcasted via this WLAN, i am using a 5508 controller and a 1131b/g AP's.
the problem is when i try to call any wireless phone from the IPPhone, the Wireless phone takes too long to show that someone is calling you.
on the IPPhone i hear it ringing when i dial the WPhone extension but it doesnt show anything on the WPhone untill the IPPhone reaches its third ring then the WPhone starts to ring.
its like:
Land phone ---> dial the wireless phone  ext. ---> ring, ring ring,--->  then you hear the Wireless phone rings for the first time after you hear 3 rings on the land phone.
i was following the 7925 phone deployment guide for configuring the phone and the controller.
any ideas.
thank you.
migilles
Would check the CU to see if their is interference, congestion, etc.
May want to try with 5 GHz if you have an 802.11a capable AP.
