7925G High Jitter/Packet loss/Audio issues
mtibrandon
We've got five 7925G's on site, all are pulling from a common profile, so apart from IP addresses and extensions they are identical.
One has been added more recently, and has persistent issues with calls cutting in and out, usually for 5-20 seconds. This happens typically several times a minute, leaving the phone unusable.
Site survey shows comparable RSSI strength to the other phones.
Looking for suggestions on where to look for a solution to this.
All Phones have a firmware version 1.4.6.3
All other settings are identical, other than the newest phone having a hardware revision of 3, compared to 2 on the other 4.
The four functioning phones report a MOS LQK of 4.5 across the board.
The phone with the issue reports something around 2 (Changes regularly) As well as having Max Jitter of 4-500 when in use.
We're using them with UCCX version 8.5 & UCCM version 8.6 if relevant.
Will add any further details requested.
ali aqrabawi
Level 3
Level 3
the first question that i would ask if i'm troubleshooting wireless phone :
does this issue occur only while the client is roaming ? or it's occur sporadically even when the client is stationary ?
please share :
show sysinfo /from the WLC
show wlan <voice WLAN id>
as this issue looks a client issue , then can you set the logging level to trace , and when you notice the issue take the time stamp of it (time should match phone time) , and download the logs from the phone GUI , share these look to have a look at them
Issue occurs at all times, regardless of roaming. (Site has a single AP only, small building with good coverage throughout)
Will attempt to pull logs. Web interface has been pretty unusable for us. Usually have to reload 10-20 times before log downloads will succeed. (Happens for all phones.)
EDIT: Attached the log file. Error occurred at 15:18 06/15/15
Excerpt from log: -15 15:18:28:0390 CP-7925G user.err SCCP: wangkai:forward show in call plane:500------>Contact Center;
2015-06-15 15:18:28:0830 CP-7925G user.info modprobe: insmod -s  -k eth0
2015-06-15 15:19:17:0080 CP-7925G user.err secd: SSL_accept:error in SSLv3 read certificate verify A
nothing interested in the phone logs ,
is the AP autonomous AP ? or OEAP connected to WLC ?
set the below to trace level on phone GUI , and try to download the logs after the occurrence:
Kernel
Wireless LAN Driver
Call Control
Network Services
Audio System
System
also collect packet capture at switchport (if possible).
*these logs will be also needed if a TAC case required .
Leo Laohoo
Good version/firmware.
Describe your WLAN?  If the WLAN are all Cisco then:
1.  What model of WLC and what firmware verison;
2.  What model of AP;
Describe your LAN.
