7925G Wireless Phone Battery New Date Code Format
We just received a new shipment of batteries for 7925G wireless phones, and noticed the date code on the battery is different. I'm wondering if anyone knows the new format.
The old format was FSYYWWXXXXX (FS+Year+Week+Series).
The new format is different. An example of date code on one of our batteries is "GL45102442".
Any ideas?
Thanks!
Justin
The info on the new batteries decodes as:
7 Replies 7
Saurav Lodh
Level 7
Level 7
The date code on the battery looks like this:
FS1015
That means manufactured in week 15 of 2010
Thanks, but that is the format from our OLD batteries, as I described in my OP. The NEW batteries don't follow that format.
I clicked on "Correct Answer" by mistake, which changed this question to "Answered". I don't see any way to undo that.
Justin
can you post a pic of the battery serial number?
Here is a photo showing 2012 and 2015 batteries.
Justin
Excellent! Thanks very much for that information!
Justin
gohussai
Level 4
Level 4
Yes just to add its always the year first. i.e 10 for the year then date of the specific month.
