8.2MR5 Interim Availability
Javier Contreras
Release 8.2.145.x Interim (8.2MR5)
Final  code 8.2.151.0 is now posted, thanks for your interest!
New Updated version 8.2.145.64
This release adds the following functionality:
  • TKIP  support for 2800/3800/1800
8.2.145.64
CSCvc18129    Crash on RF profile/client exclusion sync on HA scenario
CSCvd19354  WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b
CSCvd20843   Beacon stuck due to off-channel stuck
CSCvd25183   2800/3800 does not advertise the extension channel correctly when DCA assigns Bandwidth.
CSCvd29298  2800/3800 - Type 3 off-channel stuck due to callback missing during off-channel
CSCvd07243  Unable to change AP name nor location from the GUI
CSCvc87207  AP2800 802.11b/g radio dropping RTP packets
8.2.145.58
CSCvd16523        AP3800/2800: New CLI to make core dump extended not persistent across upgrade
CSCvc59252        1852 AP showing only power level 1 instead of power level 1 to 8 under 5 Ghz radio
CSCvd16939        1800 Band-Select does not work
CSCvd16993        2800/3800 - Rxhang Fixes
CSCvb94413        2800/3800 -  Fix DAA
CSCvd00405        Silent reboot observed for 3800
CSCvd07657        AP1810 fails to get ARP response intermittently leading to a full reboot
CSCvd18791        2800/3800 - NSS counters after next-hop-MAC failure in capwapd
CSCva91457        WLC: repeated crashes w/Reason: spamApTask4
CSCvc52619        Local EAP do not support any of ciphers, used by 8821 phone
CSCvb77682       2800/3800 -  ioctl error message when setting XOR to 5GHz band
CSCvb73104        AP 1600: Radio d1 reset: FW: irq/mac stat=40000/10000000 command timeout
CSCvd07215        1800/2800/3800 doesn't learn dhcp lease time from dhcp server and defaults to 24hr.
CSCvd09482        2800/3800 - Rxhang Fixes
CSCvd03656       AP2800/3800 not updating ndp to WLC due to Status: NSS_INVALID_PARAM
CSCvd05596        2800/3800 - Rxhang Fixes
8.2.141.40
CSCvb94799 mc2uc packet packet lost with AP 3802E
CSCvc89939 2800/3800: 40 mhz ext offset 8.2.145.33
CSCvc90559 2800/3800: RX Hang seen on alpha 8.2.145.36
CSCvc61560 WLC radius auth aaaQueueReader "Unable to fit Radius packet in allocated memory"
CSCvb78834 wlc crashing with task name emweb
CSCvc64343 AP1530 detected a lot of radars
CSCvc60233 2800/3800: Off-channel timeout is observed
CSCvc86514 2800/3800 - AP CAPWAP reset when extended Radio coredump is enabled
CSCvc81662 2800/3800: RX Hang seen on alpha 8.2.145.26
CSCvc71905 2800/3800: AP detects radar in the absence of radar sources (8.2.131.40)
CSCvc81491 2800/3800: high latency issues on on build 8.2.145.26
CSCvb94436 TKIP support for 1800 series APs
CSCvc52004 1800: iOS device connect to the dot1x network slowly
CSCvc70133 1800/2800/3800: AP flex: MC40 11g client sending Assoc req with g rates in extended rates display issue
CSCvc80161 2800/3800 11n/ac clients failing to associate with XOR in 5GHz
CSCvc11544 Default Neighbor Pruning Timer need to be increased to keep neighbor entries for 1 hour
CSCvc76148 2800/3800 Beacon drift causing mc9060 client drops
8.2.141.26
CSCur63031
AP error: %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy
CSCur68316
802AP-891 in flexconnect mode are losing vlan mapping after power cycle
CSCuw41092
AP not send traffic indication in beacon for power-save client after FT
CSCux48308
Broadcast delivery stops with key rotation 1552 rap,  819W 153.3JBB5 wgb
CSCux51833
Client fails on RAP with AAA Override ACL when AP is in Flex+Bridge Mode
CSCux78389
Radius Failover should failover both authacct server on WLAN
CSCux85357
WLC sends GARP for flex local switching clients after HA switch-over
CSCux88967
On MAC Filter failure  Client session timeout can not association back
CSCux95319
Roaming central to local auth causes in flex caused dot1x table failures
CSCux96500
WiSM2/WLC crash on bcastReceiveTask
CSCuy30583
5520 show imm chassis shows no results and crashes WLC
CSCuy53072
SNMP cLMobilityGroupMembersTable returns wrong  value from WLC in PI
CSCuy53596
CleanAir fatal error and radio reset on Flex+Bridge AP
CSCuy64520
Access Points (AP) sending CDP packets to the wireless clients
CSCuy71409
Client detailed params not synced to standby in fast ssid scenario.
CSCuy75241
5508 system crash with task mmMobility
CSCuy82849
Memory leak found@mm_heartbeat module on Guest anchor WLC
CSCuz05218
Barbados: show ap auto-rf   does not display  xor slot(0) neighbors
CSCuz11717
3-sec delay before sending "dot1x auth initiate" to SPAM with WSSI
CSCuz16883
Address registration issues for mobility scenarios
CSCuz18811
Flex: Local Switching WLAN is changing to Central Switching WLAN on add
CSCuz33818
profiler:  double free issue
CSCuz35221
Mobility handoff fails in new mobility dot1x CWA client reconnect
CSCuz40066
Guest Anchor:Foreign to Foreign roam fails on GA scenario
CSCuz40970
8510 anchor WLC Crash on task osapiBsnTimer
CSCuz49968
8.0 MR4 WLC crash during SNMP set opeartion
CSCuz50774
WLC lossing pings to itlsef Reaper cleaning up exited task osapi_ping_rx
CSCuz67292
Client not moving to RUN state after CAS perform posturing on client
CSCuz77747
Flexconnect: AP 1602 loses native vlan config on reload
CSCuz78555
Bulk sync status "In-progress" after standby boots up
CSCva01578
BARBADOS Ap not showing Syslog Server ip  with DHCP option-7
CSCva01762
AP1815/50: Over-ride Global credentials cleared on GUI after reboot
CSCva03376
UX-AP3702i After primed carrier set 5GHz only allowing four UNII3 ch
CSCva22440
3800: QBSS STA Count keeps incrementing with STA associating again
CSCva28211
AireOS UX AP : 'JP' should be used as world mode in Beacon/Probe Res
CSCva28524
WLC 8.3 - Creating SNMP community fails
CSCva31178
AP: 8.3 - Radio reset due to offchannel stuck
CSCva32411
Clients losing connectivity when reauth with DOT1X over 702w AP
CSCva48201
Unable to set static IP for AP from controller GUI
CSCva52825
2800/3800 does not do PMTU discovery during join/image download
CSCva63541
2/3800 AP CAPWAP restarts continuously during FTP transfer of large file
CSCva72724
AP2602 Crash "disc_tx_requeue_client" "dot11_get_rate_shift"
CSCva74487
8540 crash on running show commands task :emWeb
CSCva74927
Barbados Flex - AP disjoins with 'Failed to get ARP entry for WLC' error
CSCva83234
Barbados : Kernel Crash during image download
CSCva83884
WLC System crash on aaaQueueReader
CSCva87295
Flex AP radio reset during FT with Central dhcp and Nat-pat enabled
CSCva90343
Unable to do VLAN to RLAN mapping at FlexConnect Group
CSCva95251
DSCP traffic is not limited to maximum QoS Profile value
CSCvb09381
Unable to add or modify SNMP strings on a 5520 HA Pair running 8.1.122.0
CSCvb25233
Enable VLAN-RLAN Mapping in FlexConnect Group
CSCvb28231
Controller crashed due to memory corruption
CSCvb35173
Barbados: Radio crash  beacon stuck - due to lost txq reference
CSCvb43105
Barbados outer DSCP not same as inner with DSCP Trust upstream NSS
CSCvb44169
emWeb reaper reset after "clear mdns service-database all"
CSCvb44699
NMSP queue full due to Rouge AP task.
CSCvb48603
Evaluation of wlc for Openssl September 2016
CSCvb52310
Silent Boot on 2800/3800
CSCvb54166
Malformed 11v element on HSR WGB with WLC 8.2+
CSCvb66080
VLAN override from ISE is not working for RLAN with FlexConnect Local Switching
CSCvb69962
Client traps not showing session ID's
CSCvb71168
RSA256-AES256 dtls encryption lowers PMTU but AP doesnt' respect it
CSCvb72380
performance profile show all values as 0 after clear config for XOR radio
CSCvb79274
WGB wired client expiring periodically
CSCvb80511
CWA is not working for flex-bridge APs pointing ACL rx from Radius doesn't exist
CSCvb81003
WLC crashes as emWeb uses 100%
CSCvb81359
WLC 8540 HA. RMI ping and access to standby fail when using non-default ap-manager
CSCvb85576
Evaluation of wlc for CVE-2016-5195 (DIRTY CoW)
CSCvb89781
2700-B AP unable to join WLC: Unable to create temp dir "flash:/update"  LR= 0xc011e2dc
CSCvb90403
AP1810W hardware watchdog reset at PC= 0xc03b3ffc
CSCvb90793
AP name unknown in SNMP bsnDot11StationDeauthenticate traps
CSCvb92562
Evaluation of all for Openssl 1.0.1 September 2016
CSCvb94610
Restore command to disable GARP
CSCvb94697
2800/3800 11n macbook client has dropping connectivity while connecting to AP3800
CSCvb95147
AP 1572EAC unable to use 80MHz
CSCvc00358
WLC crash  "apfRogueTask_0" missed software watchdog
CSCvc09824
the AP2800 band select stats counter show zero
CSCvc13175
GLC-T SFP stopped working in CT5520 (1G Port down on 5520)
CSCvc15149
Barbados 8.2 MR4 - Not beaconing a SSID when it is in an AP group and SSID enabled later
CSCvc16755
AP3802 custom power level not initialized after reboot
CSCvc18699
Corsica: High pings drops  traffic connectivity drops seen 8.2.131.40
CSCvc23658
Clients not removed from flexconnect and capwap in APs flexconnect central-sw
CSCvc25669
rfidTask is causing a high CPU on the WLC
CSCvc29030
100MHz channel separation between 5G band with XOR in monitor mode
CSCvc31133
Unable to enable wlan with enabled selected option in GUI. Security: FT + Open
CSCvc31304
83MR1: AP syslog flood for TLV-DEC-ERR: cannot process TLV for TLV_DMS_CLIENT_REQUEST_PAYLOAD(325/0)
CSCvc32706
3800 APs: Not seeing all COS neighbors
CSCvc32856
Barbados: Sends a AQ Event as soon as RRM changes channel causing bad channel selection and changes
CSCvc33258
WLC: Unable to config RX-SOP threshold for IW3702 AP
CSCvc33511
SNMPv3 access failing with either unknown user / no response
CSCvc38214
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24
CSCvc39963
Barbados : FRA revert command failing to revert XOR to 2.4GHz
CSCvc40470
AP radio hang chatter: wl0: rxRingStuckDetect(271): RX-HANG Detected!!
CSCvc40564
TPC - Maximum/Minimum power level are not set as expected
CSCvc42566
1702I AP - radio resets observed due to CleanAir error count exceeded
CSCvc42741
AP3800/AP2800 : Failed to receive data keepalive and  Process capwapd gone
CSCvc42939
3800 AP duplicating multicast packets
CSCvc43232
2800/3800 uses 11n data rates to send data packets to 11b only clients failing to assoc
CSCvc43328
2800/3800 Sending Acks to client at 54 data rate although Basic rate is 12 & 24 in 8.2Mr4Esc
CSCvc45038
2800/3800 Beacon drift 25ms with offchannel/cleanair scanning @3sec mc9060 client drops
CSCvc48232
AP crash due to kernel panic at mhsm_transition
CSCvc50228
2800/3800 Sending Data packets to the 11g clients sometimes with messed up data rates
CSCvc50377
WLC7500: emWeb crash while doing "show run-config" on 8.0.110.11
CSCvc53578
2800/3800 11b only clients does not associate if HT is disabled
CSCvc53675
1852 AP - kernel backtrace at ol_ath_tx_mgmt_wmi_send+0x0/0x1e4
CSCvc74695
XOR radio pushes local-mode AP config for flex-mode AP causing Client disconnect
53 Replies 53
yes, this is socket error on the control component for the radio, if you reload it would recover, but the error may happen again
the only way to prevent this, is to run a fixed code
regards
SupportAC
Hi Javier,
We have opened a TAC case, because it seems we are sufering CSCvb61023 DHCP option 82. We are using an escalation version 8.1.131.34, this version fixes  CSCva95121    Stale IP route left on Flex AP config if booting up in standalone mode. do you know if version 8.2MR5 will include both fixes?
Cisco TAC told me the following:
"till now there is no clear ETA but we are pushing for the fix to be included on 8.2MR5 CCO release which should be this February"
Our end customer is a very important ISP in spain, and they are having a lot of problems with WLC bugs since they deployed EoGRE
Also TAC told me that both fixes will be included in release 8.4, this version will be avalaible at the end of February too.
    wich version do you recommend?
thank you very much for your help
At this time, this bug is planned to go into 8.2MR6, 8.4, and 8.3MR2
The fix arrived a bit late into 8.2MR5 program, so missed this release window.  We can include in 8.2 after MR5 is posted, please ask TAC to reach out to me
8.4 is a new feature release, so if what you need is a bug fix, it is not the best candidate, unless you also need one of the new HW or SW features included
regards
thank you very much for your help Javier.
They don't need any new HW or SW feature, but it is very urgent to fix the issues as soon as possible.
I think the best approach is include the fixes in 8.2 MR5.
i will ask to cisco TAC. thanks
Billy Tsang
Will MR5 fix the bug CSCut39733, thanks.
Hi Billy
CSCut39733 has been fixed since 8.2.100.0, so yes, included on this release
regards
betheric63
Hello Javier,
We loaded 8.2.141.10 per TAC suggestion.
We had the issue on our(WLC 5520) 2800s bug (CSCvc32706) When on 8.3.104.78.
This seemed to fix our issues, however we noticed the APs started reporting Half Duplex to the switch But showing Full in GUI, filling my switch logs with Duplex-Mismatch errors.
Shutting the port down and bringing it back up seems to correct on my 3750X sw. But on a few legacy switches won't clear the error.
Is this a bug or Caveat to the 8.2.141.10? Have you seen this before.
We have a TAC case opened, but Figured I would ask here.
Yes, ports configured to Auto-Neg. the Speed and Duplex.
TKIP support req'd.
Any input appreciated.
bart.t
Hi Javier,
In the first phase of a pilot deployment of 2802/5520, 6 out of 9 APs are continually disjoining and eventually rebooting.
On checking the AP syslogs created before the reload I'm seeing a lot of these:
Feb 24 08:21:44 kernel: [*02/24/2017 08:21:44.6082] CAPWAP State: Discovery
Feb 24 08:21:44 kernel: [*02/24/2017 08:21:44.6083] Got WLC settings(<wlc_ip>) from DHCP.
Feb 24 08:21:47 kernel: [*02/24/2017 08:21:47.0787] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:21:54 kernel: [*02/24/2017 08:21:54.6809] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:02 kernel: [*02/24/2017 08:22:02.2831] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:09 kernel: [*02/24/2017 08:22:09.8853] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:14 kernel: [*02/24/2017 08:22:14.6363] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
VERY_TYPE_DHCP(2) /24/2017 08:22:14.6380] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCO--More-- (66% of 8688 bytes)
Feb 24 08:22:14 kernel: [*02/24/2017 08:22:14.6390] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
Feb 24 08:22:17 kernel: [*02/24/2017 08:22:17.4875] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:24 kernel: [*02/24/2017 08:22:24.1396] CAPWAP State: Discovery
Feb 24 08:22:24 kernel: [*02/24/2017 08:22:24.1397] Got WLC settings(<wlc_ip>) from DHCP.
Feb 24 08:22:25 kernel: [*02/24/2017 08:22:25.0896] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:32 kernel: [*02/24/2017 08:22:32.6918] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:40 kernel: [*02/24/2017 08:22:40.2941] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:47 kernel: [*02/24/2017 08:22:47.8963] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:22:54 kernel: [*02/24/2017 08:22:54.1663] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
Feb 24 08:22:54 kernel: [*02/24/2017 08:22:54.1673] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCOVERY_TYPE_DHCP(2)
Feb 24 08:22:54 kernel: [*02/24/2017 08:22:54.1706] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
Feb 24 08:22:55 kernel: [*02/24/2017 08:22:55.4984] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:03 kernel: [*02/24/2017 08:23:03.1006] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:03 kernel: [*02/24/2017 08:23:03.6709] CAPWAP State: Discovery
Feb 24 08:23:03 kernel: [*02/24/2017 08:23:03.6711] Got WLC settings(<wlc_ip>) from DHCP.
Feb 24 08:23:10 kernel: [*02/24/2017 08:23:10.7028] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:18 kernel: [*02/24/2017 08:23:18.3051] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:25 kernel: [*02/24/2017 08:23:25.9072] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:33 kernel: [*02/24/2017 08:23:33.5094] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:33 kernel: [*02/24/2017 08:23:33.7018] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG(1)
Feb 24 08:23:33 kernel: [*02/24/2017 08:23:33.7029] Discovery Request sent to <wlc_ip> with discovery type set to CAPWAP_DISCOVERY_TYPE_DHCP(2)
Feb 24 08:23:33 kernel: [*02/24/2017 08:23:33.7038] Discovery Request sent to 255.255.255.255 with discovery type set to CAPWAP_DISCOVERY_TYPE_UNKNOWN(0)
Feb 24 08:23:41 kernel: [*02/24/2017 08:23:41.1116] Failed to get ARP entry for WLC <wlc_ip>
Feb 24 08:23:43 root: 2: Capwap Discovery Failed
Feb 24 08:23:43 busyboxreboot: ### reboot command [2: Capwap Discovery Failed] ###
Reset Request from Controller(Capwap Discovery Failed) Rebooting: --More-- (99% of 8688 bytes)
Feb 24 08:23:43 init: starting pid 13403, tty '': '/etc/init.d/shutdown'
So it seems the AP are hitting:
CSCva74927
But I'm not able to view the bug because of permissions. AP's are in local mode not in Flex.
Is it likely the latest interim will resolve this issue?
Hi Bart
yes, on quick check, this seems to be CSCva74927
The fix corrects a timing issue where a discovery is sent to transmit, before the IP stack is fully up
it is corrected on the current MR build.
if you see any issues, please let me know
regards
Ethan Grinnell
Any word on when this will be released? Feb has come and gone. I see that 8.3.111.0 is out, but no new releases for 8.2 yet.
Ethan
Hi Ethan
we are on final verification steps, if all goes well, it should be posted by next week
regards
Thank you
Eagerly awaiting release to see if it addresses undesirable behavior I'm seeing with 702W connected wired and wireless clients.
frank_hsu
Hi Javier,
       We had 28 2802 series( E and I). Some of them (about 5) meet the bug CSCva98904 (2800/3800 reload: rcu_sched self-detected stall). We plan to upgrade to 8.3 MR1. We check the release note of 8.3 MR1. The bug CSCva98904 is open caveats in Release 8.3.111.0,but it had been fixed in 8.2(131.5) by your bug search notes. But  we also check the release notes of 8.2(130) and 8.2(141) ,the bug CSCva98904 had not been listed in resolved caveat list.
Does the CSCva98904 has been fixed in 8.2 MR4 or 8.2 MR5? If it is correct . Can we upgrade WLC OS to the fixed version(just to fix AP bootloader) , and then upgrade WLC to 8.3.110 ?
Sorry for my pool english.
Thanks!
Hi Javier:
         Do I need to open TAC case to check CSCva98904 status?
Thanks!
[11/25/2016 13:36:30.1100] INFO: rcu_sched self-detected stall on CPU[11/25/2016 13:36:30.1800] INFO: rcu_sched detected stalls on CPUs/tasks: { 1} (detected by 0, t=1351372 jiffies, g=4294967241, c=4294967240, q=6975)
 running      0  3711   3583 0x00000006
[11/25/2016 13:36:30.3800] Backtrace:
[11/25/2016 13:36:30.4200] [<bc9a5cfc>] (0xbc9a5cfc) from [<bc9a5d24>] (0xbc9a5d24)
[11/25/2016 13:36:30.5100] Backtrace aborted due to bad frame pointer <00000002>
[11/25/2016 13:36:30.6000]  { 1}
-rw-r (t=1351422 jiffies g=4294967241 c=4294967240 q=6975)
--r--    1 root [11/25/2016 13:36:30.7100] CPU: 1 PID: 3711 Comm: insmod Tainted: G           O 3.14.33 #1
[11/25/2016 13:36:30.7100] Backtrace:
    root        [11/25/2016 13:36:30.8600] [<8010a5dc>] (dump_backtrace) from [<8010a89c>] (show_stack+0x18/0x1c)
[11/25/2016 13:36:30.9800]  r6:809340c0 r5:bf7e66d8 r4:00000000 r3:00400100
  4096 Feb 21  2[11/25/2016 13:36:31.0600] [<8010a884>] (show_stack) from [<8066b9f4>] (dump_stack+0x70/0x8c)
017 random_seed
[11/25/2016 13:36:31.1800] [<8066b984>] (dump_stack) from [<801675d8>] (rcu_check_callbacks+0x210/0x6b4)
[11/25/2016 13:36:31.1800]  r4:80942f80
-rw-r--r--    1 r3:80942c08
 root     root  [11/25/2016 13:36:31.3700] [<801673c8>] (rcu_check_callbacks) from [<801294d4>] (update_process_times+0x40/0x64)
[11/25/2016 13:36:31.3700]  r10:801719b4 r9:8092f2f0 r8:bc9a5a80 r7:00000001 r6:00000000 r5:beacc000
           3 Sep[11/25/2016 13:36:31.6200]  r4:bc9a4000
 13 00:00 rxtx_m[11/25/2016 13:36:31.6800] [<80129494>] (update_process_times) from [<80171b88>] (tick_sched_timer+0x1d4/0x220)
[11/25/2016 13:36:31.6800]  r7:bf7e62f0 r6:bf7e6328 r5:7fffffff r4:bf7e6920
ode
-rw-r--r-- [11/25/2016 13:36:31.8900] [<801719b4>] (tick_sched_timer) from [<8013da04>] (__run_hrtimer+0x108/0x204)
[11/25/2016 13:36:31.8900]  r10:801719b4 r9:8092f2f0 r8:bc9a5a80 r7:bf7e62f0 r6:bf7e6328 r5:7fffffff
   1 root     ro[11/25/2016 13:36:32.1300]  r4:bf7e6920
ot            64[11/25/2016 13:36:32.1800] [<8013d8fc>] (__run_hrtimer) from [<8013e3bc>] (hrtimer_interrupt+0x138/0x2c4)
[11/25/2016 13:36:32.1800]  r10:bf7e62f0 r8:3eeb7000 r7:00000000 r6:31a6d700 r5:7fffffff r4:ffffffff
 Feb 21  2017 se[11/25/2016 13:36:32.4200] [<8013e284>] (hrtimer_interrupt) from [<8010d8a4>] (twd_handler+0x34/0x40)
[11/25/2016 13:36:32.4200]  r10:bf7eb1c0 r9:bf3d6480nsord_CSPRNG0
- r8:80950a54rw-r--r--    1 r r7:0000001doot     root     r6:8093b374        64 Feb 2 r5:bf018280
1  2017 sensord_[11/25/2016 13:36:32.7100]  r4:00000001CSPRNG1
drwxr-x
r-x    3 support[11/25/2016 13:36:32.7900] [<8010d870>] (twd_handler) from [<80160b88>] (handle_percpu_devid_irq+0xa4/0x12c)
  root          [11/25/2016 13:36:32.9200]  r4:bf008600 224 Sep 13 00:0 r3:8010d8700 support
drwxr
-xr-x    2 root [11/25/2016 13:36:33.0300] [<80160ae4>] (handle_percpu_devid_irq) from [<8015d10c>] (generic_handle_irq+0x28/0x38)
    root        [11/25/2016 13:36:33.1600]  r10:007cd000 r8:7f0b9068   976 Nov 25 09 r7:bc9a5b7c r6:8093b374:51 syslogs
--- r5:00000000 r4:0000001d
----------------[11/25/2016 13:36:33.3200] [<8015d0e4>] (generic_handle_irq) from [<801071c8>] (handle_IRQ+0x6c/0x94)
----------------[11/25/2016 13:36:33.4400]  r4:0000001d r3:000000fe----------------
----------------[11/25/2016 13:36:33.5400] [<8010715c>] (handle_IRQ) from [<801004c0>] (gic_handle_irq+0x44/0x68)
[11/25/2016 13:36:33.6600]  r5:bc9a5b48--------
Filesy r4:c0802100
stem            [11/25/2016 13:36:33.7300] [<8010047c>] (gic_handle_irq) from [<80672d40>] (__irq_svc+0x40/0x50)
    Size      Us[11/25/2016 13:36:33.8400] Exception stack(0xbc9a5b48 to 0xbc9a5b90)
ed Available Use[11/25/2016 13:36:33.9300] 5b40:                   00000000 00000000 c3600000 c3600000 bf3d6000 8093a400
% Mounted on
fl[11/25/2016 13:36:34.0600] 5b60: b8600000 00028e24 7f0b9068 bf3d6480 007cd000 bc9a5bcc c360e000 bc9a5b90
ash             [11/25/2016 13:36:34.1900] 5b80: 00000100 7f011470 60000013 ffffffff
       57.5M    [11/25/2016 13:36:34.2800]  r6:ffffffff r5:60000013232.0K     54.3M r4:7f011470 r3:00000100   0% /storage
[11/25/2016 13:36:34.4100] [<7f011334>] (wlFwDownload [ap8x]) from [<7f02b704>] (wlInit+0x4f8/0x1304 [ap8x])
[11/25/2016 13:36:34.5300]  r10:bf3d6000 r9:00028e10 r8:00028e1c r7:00028e24 r6:00028e18
# r5:00000000
[11/25/2016 13:36:34.6300]  r4:bf3d6480
[11/25/2016 13:36:34.6700] [<7f02b20c>] (wlInit [ap8x]) from [<7f02ca08>] (wlprobe+0x4f8/0x818 [ap8x])
[11/25/2016 13:36:34.7800]  r10:7f0b9450 r9:bf3d6480 r8:f8200000 r7:c3600000 r6:7f0be35c r5:bf0e7000
[11/25/2016 13:36:34.8900]  r4:bf3d6000
[11/25/2016 13:36:34.9300] [<7f02c510>] (wlprobe [ap8x]) from [<8039623c>] (pci_device_probe+0x60/0xa4)
[11/25/2016 13:36:35.0400]  r10:00002b40 r9:00000000 r8:7f0b94a4 r7:00000000 r6:7f0b94d8 r5:bf0e7000
[11/25/2016 13:36:35.1500]  r4:bf0e7068
[11/25/2016 13:36:35.1900] [<803961dc>] (pci_device_probe) from [<803d4dec>] (driver_probe_device+0xb4/0x1fc)
[11/25/2016 13:36:35.3100]  r8:7f0b941c r7:00000002 r6:7f0b94d8 r5:00000000 r4:bf0e7068 r3:803961dc
[11/25/2016 13:36:35.4100] [<803d4d38>] (driver_probe_device) from [<803d4fa4>] (__driver_attach+0x70/0x94)
[11/25/2016 13:36:35.5200]  r7:803d4f34 r6:7f0b94d8 r5:bf0e709c r4:bf0e7068
[11/25/2016 13:36:35.6000] [<803d4f34>] (__driver_attach) from [<803d34c8>] (bus_for_each_dev+0x5c/0x98)
[11/25/2016 13:36:35.7200]  r6:7f0b94d8 r5:bc9a5d48 r4:00000000 r3:803d4f34
[11/25/2016 13:36:35.8000] [<803d346c>] (bus_for_each_dev) from [<803d4940>] (driver_attach+0x20/0x28)
[11/25/2016 13:36:35.9000]  r7:80959ce4 r6:00000000 r5:bea11700 r4:7f0b94d8
[11/25/2016 13:36:35.9800] [<803d4920>] (driver_attach) from [<803d457c>] (bus_add_driver+0xd8/0x1d8)
[11/25/2016 13:36:36.0900] [<803d44a4>] (bus_add_driver) from [<803d5698>] (driver_register+0xa4/0xe8)
[11/25/2016 13:36:36.2000]  r7:7f0b9450 r6:00000002 r5:0000001c r4:7f0b94d8
[11/25/2016 13:36:36.2800] [<803d55f4>] (driver_register) from [<80396340>] (__pci_register_driver+0x40/0x48)
[11/25/2016 13:36:36.4000]  r5:0000001c r4:7f0b941c
[11/25/2016 13:36:36.4500] [<80396300>] (__pci_register_driver) from [<7f27015c>] (wlmodule_init+0x15c/0x194 [ap8x])
[11/25/2016 13:36:36.5700] [<7f270000>] (wlmodule_init [ap8x]) from [<801007ac>] (do_one_initcall+0x9c/0x140)
[11/25/2016 13:36:36.6900]  r10:7f0be21c r8:7f270000 r7:00000001 r6:7f0be1e0 r5:00000000 r4:7f0be1d4
[11/25/2016 13:36:36.8000] [<80100710>] (do_one_initcall) from [<8017b034>] (load_module+0x1928/0x1c04)
[11/25/2016 13:36:36.9100]  r10:7f0be21c r9:00000001 r8:bc9a7d40 r7:00000001 r6:7f0be1e0 r5:00000000
[11/25/2016 13:36:37.0100]  r4:7f0be1d4
[11/25/2016 13:36:37.0500] [<8017970c>] (load_module) from [<8017b3d8>] (SyS_init_module+0xc8/0xe0)
[11/25/2016 13:36:37.1600]  r10:00000000 r9:bc9a4000 r8:80106408 r7:00000080 r6:001c6008 r5:000e93e4
[11/25/2016 13:36:37.2700]  r4:76e0c008
[11/25/2016 13:36:37.3100] [<8017b310>] (SyS_init_module) from [<80106260>] (ret_fast_syscall+0x0/0x30)
[11/25/2016 13:36:37.4200]  r6:001c6008 r5:76e0c008 r4:7eea7f0a
bart.t
Hi Javier,
Regarding the SNMPv3 bug (CSCvc33511) I'm still not able to manage a 5520 (latest .67 code) with SNMPv3 using Prime Infra 3.1.5 (DP7). Reload as suggested does not work either. SNMPv2c does work. Tried longer and shorter usernames and passwords and both SHA1/AES and MD5/DES. Older WLC5508 can be managed with SNMPv3 using Prime.
On debugging SNMP on the (active) WLC, I receive the following (filtered on SNMPD only):
 *SNMPTask: Mar 06 12:53:17.988: [PA] SNMPD: Packet from: <ip_prime>:63556, in_packet_len = 155
 *SNMPTask: Mar 06 12:53:17.988: [PA] SNMPD: Failed to build SnmpMessage error code = 603
 *SNMPTask: Mar 06 12:53:17.988: [PA] SNMPD: *NOT* sending out packet, out_packet_len = 0
 *SNMPTask: Mar 06 12:53:23.232: [PA] SNMPD: Packet from: <ip_prime>:9414, in_packet_len = 144
 *SNMPTask: Mar 06 12:53:23.232: [PA] SNMPD: calling srDoSnmp.
 *SNMPTask: Mar 06 12:53:23.232: [PA] SNMPD: received get pdu
 *SNMPTask: Mar 06 12:53:23.232: [PA] SNMPD:calling do_response
 *SNMPTask: Mar 06 12:53:23.233: [PA] SNMPD: Sending SNMP packet to <ip_prime>:9414, out_packet_len = 147
 *SNMPTask: Mar 06 12:53:27.989: [PA] SNMPD: Packet from: <ip_prime>:63556, in_packet_len = 155
 *SNMPTask: Mar 06 12:53:27.989: [PA] SNMPD: Failed to build SnmpMessage error code = 603
 *SNMPTask: Mar 06 12:53:27.989: [PA] SNMPD: *NOT* sending out packet, out_packet_len = 0
 *SNMPTask: Mar 06 12:53:37.989: [PA] SNMPD: Packet from: <ip_prime>:63556, in_packet_len = 155
 *SNMPTask: Mar 06 12:53:37.989: [PA] SNMPD: Failed to build SnmpMessage error code = 603
 *SNMPTask: Mar 06 12:53:37.989: [PA] SNMPD: *NOT* sending out packet, out_packet_len = 0
 *SNMPTask: Mar 06 12:54:01.871: [PA] SNMPD: Packet from: <ip_prime>:9414, in_packet_len = 49
 *SNMPTask: Mar 06 12:54:01.871: [PA] SNMPD: calling srDoSnmp.
 *SNMPTask: Mar 06 12:54:01.871: [PA] SNMPD: received get pdu
 *SNMPTask: Mar 06 12:54:01.871: [PA] SNMPD:calling do_response
 *SNMPTask: Mar 06 12:54:01.871: [PA] SNMPD: Sending SNMP packet to <ip_prime>:9414, out_packet_len = 52
 *SNMPTask: Mar 06 12:54:01.876: [PA] SNMPD: Packet from: <ip_prime>:9414, in_packet_len = 71
 *SNMPTask: Mar 06 12:54:01.876: [PA] SNMPD: received get pdu
 *SNMPTask: Mar 06 12:54:01.876: [PA] SNMPD:calling do_response
 *SNMPTask: Mar 06 12:54:01.876: [PA] SNMPD: Sending SNMP packet to <ip_prime>:9414, out_packet_len = 94
 etc...
Any idea what is happening and how to fix?
