04-07-2017 02:21 AM - edited 07-05-2021 06:49 AM
We are pleased to announce Beta Refresh Release for 8.3MR2.
Please Register at below link to participate in the Beta Program. Once Registered a separate Email will be received with Software Download Link.
Resolved Caveats
Identifier | Headline |
CSCvb05067 | Local EAP fails after wrong username login |
CSCve01552 | Unknown Username when switching from open to dot1x SSID |
CSCve13183 | AP2800/3800/1800 WCPD Crash with clients connected and can't recover after crash |
CSCuz47559 | error saving config file happens on multiple 2702 |
CSCve34143 | Wlan-vlan mapping not working sometime when ap removed and added back in flex grp |
CSCvd20251 | DP stopped working on 5508 running 8.0.140.0 |
CSCvb93365 | WLC msglog showing a lot of traceback |
CSCvd72432 | LocalEAP LDAP Request With Incorrect Password Lockout Users |
CSCve05840 | Addition of DP show commands as part of show run-config |
CSCvb74948 | AVC - CISCO-JABBER-IM application is getting misclassified as SSL |
CSCvd36259 | ME Controller intermittently Flaps with external AP. |
CSCvd96491 | SR: Rest/API for WLC exposing Assurance login password |
CSCux11777 | 1532 non-root bridge high retransmission and latency rate |
CSCvb62874 | Radio interface Input queue gets filled on Autonomous APs. |
CSCvc49713 | AP generates flood of Received and decoded a DMS client request payload SUCCESSFULLY |
CSCvc81929 | Mobility Express crashes when DHCP screen is accessed |
CSCvd58113 | wlc allowing telnet and ssh over ipv6 on global telnet and ssh disabled |
CSCvd66657 | AP 3802: SensorD stuck in offchannel causing radio stops working |
CSCvd90117 | AP3800 - Radio crashing frequently due to beacon stuck |
CSCvd92166 | Couldn't pass host testie build in the branch 8.3 mr throttle in richardson ads, but can pass in sjc |
CSCvd99909 | 8.3 MR2: AP 3800 - 5G Radio crashes - when SI enabled |
CSCve07524 | In GUI 11ac config behavior mismatch with CLi for different AP mode |
CSCve06701 | Client stuck in DHCP_REQD on flex AP after changing native vlan |
CSCvd43728 | Ap1850 DTLS Teardown after channel change |
CSCve18484 | Clear data icon is not working if other languages like korean,japanese is selected in browser |
CSCve13073 | MC9090 doesn't join with 11g disabled |
CSCve01109 | SXP connection on WLC stays off. |
CSCve21379 | During Auto Provisioning Feature, Radius Server Templates are getting applied but staying Disabled. |
CSCvc44293 | 8.4 - ME UI - Changing Transmit power on UI does not work |
CSCvd67178 | Anchor not deleting webauth req client beyond webauth timeout |
CSCve09531 | v6udp_csum_buf overshooting the buffer resulting in WLC crash |
CSCvc81082 | Polaris XOR: The radio is updated as UP whenever AP's XOR band is configured eventhough POE is low |
CSCve17730 | Kernel panic seen due to wlTxDone in 8.2.151.7 |
CSCux97132 | AP starts CAC timer after rolling back to lower bandwidth |
CSCvd53205 | DCA lists in RF profiles are broken after backup/restore the WLC's config |
CSCvd87065 | WLC crash due to task nmspTxServerTask |
CSCve17355 | Upgrade to WLC - 8.3 software enables 11k & 11v by default on all WLANs |
CSCvc41484 | Corsica: high failure rate in off-channel operation, QCA 2721453 |
CSCvc86951 | AP1850 beacon miss/corruption during downstream traffic test, QCA 02793762 |
CSCvc98310 | AP 1830: 2.4-GHz radio stopped working @0x009915D7, QCA 02797962 |
CSCvd18732 | AP 1810 radio FW Assert @0x0099B2DA in overnight multi-client test, QCA 02818890 |
CSCvd28594 | Client association fail after altering data rates in AP 1830. |
CSCvd28645 | AP sending RTS at 6 data rate when data rate 6 is disabled, QCA 02829301 |
CSCvd77037 | AP1832 sending instant ACK after CTS that block data from client, QCA 02862955 |
CSCve00464 | AP1852 detects high noise level on 5-GHz radio for every channel except the serving one |
CSCve10751 | Clients cannot assocate with AP after changing from DFS to non-DFS channels during CAC, QCA 02910240 |
CSCvb57350 | SNMP trap for "AP Interface Up/down Traps" not getting generated. |
CSCvd69782 | Roaming L3 test was failed with 50% in Talwar and Pata WLC |
CSCvd80962 | 8.3MR2: LWAPP-3-AP_LOCK_ERR traceback observed on WLC for AP2800/3800 AP |
CSCvd81926 | CCX Proxy arp flag not set in IOS APs |
CSCve08894 | Unable to debug VRRP issues unless have devshell access |
CSCvb70551 | COS AP's rebooted due to Kernel Panic-Not Syncing: Out of Memory |
CSCvc81429 | 8.2MR5: AP3800 throughput drop in client scale test with random client MAC addresses |
CSCvd61747 | AP3800: Radio crash due to off channel stuck due to defer_chchange_flag always set to TRUE |
CSCvd91894 | 3800/2800 kernel panic crash PC is at mv_dev_kfree_skb+0xc/0xa4 [ap8x] |
CSCvd96867 | Sanity: radio1FW core found in ap1560 with 8.4.2.52 |
CSCve14081 | AireOS: Same channel has been assigned to both the 5Ghz Radios after capwap restart |
CSCuw45964 | Mobility Express: While Editing a WLAN in HTTP session ,user is getting logged out |
CSCvd37808 | 8510 WLC stopped working - iappSocketTask |
CSCvb04932 | APs not discovered because of wrong bsnAPIfType returned for 1810W |
CSCvd06463 | AMSDU packets tx cause 5sec gap of packet tx to 8821 from IOS AP |
CSCvd44446 | Retried EAP Response Dropped as a duplicate while First EAP Response was not even received on the AP |
CSCve30199 | CCKM PMK (Version 2) message flooding 8.3MR2 |
CSCve23103 | AP3800: False RADAR detection without RADAR source |
CSCve23874 | BARBADOS-Client got associate immediately even if CAC timer start on AP log ,when DFS channel is set |
Resolved Caveats
CSCvc67005 | 2802 AP drops client ARP packets after web authentication |
CSCvc08052 | DFS false detection on AP2700 |
CSCva90265 | iPAD PRO with IOS10 is getting deauthenticated at times due to M3 timer |
CSCvc86170 | ClickAP FlexConnect Local Auth doesn't work on WLAN with CCKM security |
CSCvd85995 | AP3800:AP deauth client after roaming and doesn't send deauth when client sends qos null |
CSCvd18773 | 8.2 clients unable to authenticate 'Sending assoc-resp with status 12 station' |
CSCvd90669 | Need support for AAA override w/ MAC filtering on RLAN |
CSCvd79597 | Smart License 5520/8540 : Unable to reset HTTP-Proxy on Call home configuration from GUI |
CSCvd70755 | AIR-AP3802I crash due to kernel panic |
CSCvc49492 | AP1852 detects high noise level on 5-GHz radio |
CSCvd56581 | Client not getting IP address when moving between SSID |
CSCvd14806 | APs randomly not showing any neighbors on both radios |
CSCvd97103 | IPv4 CPU ACL - IP-Address with netmask other than 255.255.255.255 doesn't work |
CSCvd98548 | Kernel panic inside ForwardFrame function! |
CSCva17630 | WLC sends warm-start trap instead of cold-start during autoprovisioning |
CSCvd54154 | All AP1850 connected to master AP crash in a loop due to watchdog reset |
CSCvd86274 | 1800/2800/3800 Series AP does not send the Platform value via CDP when it is brand new |
CSCvc74876 | 8.2.145.21: Barbados CAPWAP disconnect then stuck in discovery loop |
CSCvd91770 | Trust-DSCP-Upstream broken on 8.2.151.0 |
CSCvd88630 | AP 3800: Ap crash due to 'wcpd' in 8.4 |
CSCve01859 | With FIPS enabled on 5520WLC, 3802AP shows no 5Ghz neighbors |
CSCvc82845 | WLC returns nothing for SNMP get WEB ACL - cldcClientAaaOverrideAclName |
CSCvd36736 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
Resolved Caveats
CSCvd40646 | AP2802 - Kernel Panic - Dot11Classifier: Mgmt frame not supported 0 |
CSCvd69992 | AP: 2800/3800 unable send proper sequence# and burst rate upstream |
CSCva44397 | WLC gateway not reachable after disabling LAG |
CSCvc15976 | Trustsec: AP: Not able to enable/disable AP inline tagging and SGACL Enforcement via SNMP |
CSCvb54392 | 3800: MacBook Pro Clients with OS X 10.11 getting stuck in DHCP_REQ |
CSCvd46216 | AP1832 sometimes does not send authentication response |
CSCvd46314 | Standalone COS AP should reject new client if MAC auth is configured |
CSCvd72664 | 1850 AP sometimes tags 802.1q vlan for native WLAN, causing ARP packet drop |
CSCvd74063 | AP1832 Crash due to watchdog reset(wcpd no heartbeat) |
CSCva26821 | Auto Anchor Deployment: Scheduling deletion of Mobile Station fails |
CSCvb77390 | WLC stopped working accessing MAC Address Database |
CSCvd32632 | Standby Controller stopped working @rmgrReboot |
CSCvd42348 | Standby WLC stopped working on performing SNMP Set on bsnDot11QosProfileEntry |
CSCvc85164 | 11k: WNM neighbor report is empty in when WLAN ID is greater than 1 |
CSCvd61977 | 2800/3800 -radio coredump generation may stuck ca_status leading to IPC call function failures |
CSCva33212 | Re introduce auto provisioning feature on WLC 2504 running 8.0 |
CSCva46506 | Flexgroup RADIUS configurations are not pushed to AP |
CSCva84030 | Increase CLI WLC username and password to 128 char for TACACS support. |
CSCva88600 | Evaluation of WLC for TCP August 2016 |
CSCvb71600 | WLC stopped woking after applyng CPU ACL |
CSCvc40852 | 82MR4. Active controller in HA pair shows different socket errors |
CSCvd50044 | System stopped working multiple times on ping rx task |
CSCva88319 | 5508-HA-WLC stopped working with Task Name: TransferTask |
CSCvb64042 | WLC HA transfer download failure with legitimate network latency |
CSCvb93189 | AP drops Retransmitted M3 from WLC |
CSCvd15742 | AP crash with %ENTROPY-0-ENTROPY_ERROR: Unable to collect sufficient entropy |
CSCvd83741 | AP: 1850 unable send proper sequence# and burst rate upstream from AP to MSE |
CSCvd30952 | RM3010L-B-K9 Hyperlocation Module stopped working |
CSCvd81303 | 2800/3800: Limit 'best' DCA to 80 MHz also for RF profiles |
CSCva14667 | GET on Ap groups Table after set - response missing |
CSCvc94648 | Evaluation of wlc for OpenSSL Jan 2017 |
Resolved Caveats
CSCvd24540 | SNMP System crash when tried to create tunnel with clGatewayTunnelEntry MiB |
CSCvd19354 | WLC crash while editing config rf-profile hsr-mode disable | enable config rf-profile 11b |
CSCuz47786 | FlexConnect AP sending IGMP report to WLC for local switching WLAN |
CSCvb86157 | clients can't connect anymore to vWLC- Instrumented code added |
CSCvc67465 | Flex AP loses vlan mapping if vlan tagging is enabled. |
CSCvd37960 | 83MR2-clients getting re-anchored if critical application is present on client |
CSCvb64560 | CISCO-LWAPP-AAA-MIB: DEFVAL format incorrect for some objects |
CSCvb67724 | 5508 is going out of memory |
CSCvb69962 | Client traps not showing session ID's |
CSCvb98859 | AP in local sw/local auth disconnect EAP-SIM client idle for more than 0.5 second |
CSCvc52210 | After reboot of the Master AP, CMX connector service has to be disabled/enable for Test link to work |
CSCvd33140 | ME 8.4 - Constant increase in WLC Memory reaching 90% and above |
CSCvd35988 | 8.5 5520WLC-HA causing DENY rule on WLC and Telnet&Gui access down |
CSCvb20553 | Coa for session timeout not working using free radius server |
CSCvb53368 | validate rogue clients against AAA not work |
CSCvc11630 | Radio reset in switching to connected mode from standalone |
CSCvc24485 | #APF-3-UNKNOWN_RADIO_TYPE: [SS] apf_utils.c:571 Unknown Radio Type 0 from Standby flooding syslog |
CSCvc65675 | WLC: Constantly increasing memory consumption by SNMPTask |
CSCva72390 | 8.4.1.27 - Corsica in Bridge intermittently stalls show commands ... |
CSCvc03468 | 2800/3800: Packets not beamforming with beamforming enabled. |
CSCvc49263 | RLAN-VLAN mapping misconfigured after moving to secondary |
CSCvc55328 | AP crash due to kernel panic at WlLoadRateGrp |
CSCvc86979 | 2800 AP silent reboot with NUL print every 10 mins continuously |
CSCvc93398 | AP2800/AP3800 MU-MIMO forms MU groups with 2SS clients |
CSCvc95222 | 1810w LAN port dropping IPTV packets when wired device is 100M(QCA 02835075) |
CSCvd20271 | Ap 3800 crash 8.3.104.131 in Monitor mode with wips submode |
CSCvd27285 | ME_1852E : CCO image download re-initiated on the APs on which the Dwnld was alrady completed |
CSCvd29564 | Layer 2 Packet Drop Of CDP Packets for COS APs |
CSCvd35231 | AP1810W: Reload Reason: 0: Unknown aka Silent Reboot |
CSCva99545 | Invalid information displayed in show cert webauth/webadmin |
CSCvb45130 | Part of ATF config is not pushed to uploaded config |
CSCvb62478 | Wlan is allowed to be enabled when FT enabled without FT-psk/FT-802.1x |
CSCvc61652 | m25/1.0 is shown in client info |
CSCvc63169 | Flex AP specific WLAN-VLAN Mapping lost on rebooting the AP |
CSCva99052 | Configuring 1810W to OEAP does not enable DHCP on Local port LAN3 |
CSCvb29996 | 1810W Hardware Watchdog reset crash PC=0xc03b3ffc, LR=0xc008af24, QCA 02698633 |
CSCvb54306 | 1815: LED blikning green - light green even at full power and clients connected |
CSCvc07184 | Media streaming behavior different between 1560/3800 and 3700 |
CSCvd20843 | Beacon stuck due to off-channel stuck |
CSCvd21051 | AP3800: Kernel crash at wlTxDone+0x190/0x688 [ap8x] |
CSCvd51674 | AP1810W: Silent reboot : revert highest power table value |
CSCva81406 | WLC - Unmap deauth reason codes 13-22 from reason code 15 exclusively |
CSCva92917 | Observed Traceback logs in show msglog and logging |
CSCvc83583 | 5520 controller crashed with taskname apfProbeThread |
CSCvc87433 | Webauth with proxy doesn't work after 8.2 |
CSCvc88997 | FRA probe suppression config not saved after WLC reboot |
CSCvd01586 | WLC crash - Task Name: RRM-DCLNT-2_4 | rrmClientCoverageHoleAlgorithm |
CSCvd05332 | After changing AP mode to FlexConnect, AP does not assign IP to RLAN clients |
CSCvd06848 | crash SNMPTask Reason:System Crash |
CSCvd07423 | AP firmware corrupt after power cycle bad mzip file, unknown zip method reboot loop |
CSCvd15404 | Rule creation with CLRuleConfigEntry crashes the controller |
CSCvc07521 | AP3800 sends A-MSDU larger than client can handle |
CSCvd25231 | Collect Stack info for silent reboot of 2800/3800 |
CSCvd33219 | AP 3800: FW hang detected - chatter: wl1: fwHangDetect(357): FTR! |
CSCuz16883 | Address registration issues for mobility scenarios |
CSCva68921 | WISM2 reaperWatcher got stuck on DP0 while retriving crash and crashed |
CSCva77707 | AIR-CT5508 SSO ARP request out redundancy management sent with wrong MAC |
CSCva79367 | Cannot add or delete Syslog Servers To WLC |
CSCvb44979 | WLC Local EAP with 7925 Handshake Failure |
CSCvc04089 | 2700 series AP radio resets reason code 71 RADIO_RC_NO_REPORT |
CSCvc12594 | Controller fails to send SNMP when using untagged interfaces on different ports |
CSCvc78510 | 2702 aux port goes to disabled after the ap is rebooted |
CSCvd53765 | After restarting WLC NMSP goes down on CMX |
CSCuz70879 | MAP reloads on hitting 40 mins timer even when it is downloading image |
CSCva06617 | 8.3Beta :Globally configured ATF mode not applied to newly joined AP2700 |
CSCva20342 | WGB uses incorrect MAC while trying to setup BA |
CSCva31890 | MIB table bsnMobileStationPerRadioPerVapTable has no data |
CSCva39537 | 802.11h configuration not saved after restoring config backup |
CSCva40580 | 8.3:BulkSync on active wlc never completes and is stuck in 'in-progress' |
CSCva83802 | HA: SSH on redundancy management interface rejected |
CSCva91483 | AP2700 failing co-channel fairness with Samsung S5 |
CSCvb11778 | 8.1.131.18 WLC crash on sisfSwitcherTask |
CSCvb48354 | RRM Not updating as per configured on WLC |
CSCvb57779 | APs unable to join WLC in different subnet through gateways with proxy-arp disabled. |
CSCvb61023 | DHCP Option 82(remote-id) not present is some AP |
CSCvb81940 | Vlan tagging for external module removed from Ap after upgrade to 8.3.102.0 |
CSCvc39231 | SNMP GETBULK on cLIpsecProfileTable returns with No response from controller |
CSCvc68156 | Full support for "distance" on AP1572 |
CSCvc79811 | When adding/removing country codes 2.4GHz channels change |
CSCvc83490 | Redundancy Mobility MAC does not stay, Primary WLC's MAC is always set instead |
CSCvd09240 | Local-auth EAP-TLS win10 not working |
CSCvc62277 | 5520 crashes on running rrm commands on task emWeb |
CSCvc85328 | AP1832/1852: Power injector/Normal mode inspite of power supply by AIR-PWR-C |
CSCvd15394 | 3800 AP will reject login for login credentials with childer ~ in password |
CSCuz77859 | Flexconnect: AP specific DHCP-NAT-PAT config does not apply in the WLC |
CSCvb12026 | Client Load Balance export to Anchors Fails with New mobility enabled |
CSCvb51570 | WISM 2 crashed on upgrade to 8.3.102.0 with Task Name: spamApTask6 |
CSCvb89781 | 2700-B AP unable to join WLC: Unable to create temp dir "flash:/update" |
CSCvb97383 | WLC deauthenticating roaming client with idle timeout |
CSCvc33793 | WLC tears down connected AP due to unequal loadbalance between SPAM queues high load |
CSCvc83175 | VWLC does not learn client IP / Client stuck in DHCP_REQD |
CSCvd00067 | wired WGB client is removed from parent AP's association table |
CSCvd18025 | anchor1 wlc does not free client sessions after client roaming to anchor2 wlc-client entries stale |
CSCvd21155 | WLC Crash when multicasting traffic and accessing WLC GUI |
CSCvd21969 | AAA AVC Override - AVC profile retained after roaming |
CSCvd41350 | 83mr2-8500 crash osapiReaper fatal condition at broffu_fp_dapi_cmd.c:4574 |
CSCvd56671 | WLC Crash : Task 'apfMsConnTask_0' in 8.3 MR2 |
CSCvc94524 | 2800/3800 iphone & android phones are not getting ipv6 addresses |
CSCvd00289 | 2800/3800 capwapd init unsuccessful creating 2 capwapd causing WCPD watchdogd reset |
CSCuz45986 | CWA not working on 8500 as Guest anchor with Accounting enabled |
CSCva66176 | AP drop of from Network due to large set of Mobility groups in down/down |
CSCva95121 | Stale IP route left on Flex AP config if booting up in standalone mode |
CSCvb13666 | WiSM2 crash with Task Name 'IPv6_Msg_Task' |
CSCvb15871 | aIOS not forward broadcast multicast frames with dynamic vlan |
CSCvb16806 | 5500 MC showing stale connections from MA clients |
CSCvb33076 | WLC: GUI does not allow to change sniffer channel |
CSCvb96009 | WLC Crashed on emweb task on 8.3.102 |
CSCvb99468 | AirOS WLC crashed in emWeb when serving an EmWebForm exclusion-list |
CSCvc66352 | 5500 controller crashed with taskname emweb |
CSCvc74515 | 8.2.121.11/8.2.124.15 : WLC Data plane crash due to fragmentation |
CSCvc78546 | WLC sets Zero 11e QoS for downstream voice traffic when CAC is disabled |
CSCvd39346 | 2800/3800 WCPD slow memory leak |
CSCvd49909 | Kernel panic @ ClientCapabilitiesTracker virtual address invalid |
CSCvb91652 | PMIPv6 Sluggish cli/gui response as well as sporadic lack of snmp response |
CSCvc23724 | WLC crash with EoGRE Heartbeat and skip count configured with value 0 which makes tunnel dead |
CSCvc65568 | 8821 fails 11r FT roam with "Invalid FTIE MIC" |
CSCvc82053 | The nmsp info/probe notification queue is saturating |
CSCvc82376 | EAP-TLS certs and PMK cache are missing on Flex AP after reload |
CSCvd12057 | Flex AVC : Downstream QoS marking not working - 8.3 |
CSCvd56064 | Flex local switching, local auth not supported when PMF is enabled in 8.3.114.22 |
CSCvd61701 | SSH to Standby RMI or Service port Fails |
CSCuq05475 | Controller GUI shows AP's NAT IP instead of private |
CSCvb12565 | WLC stops working when running 'show run-config' command with no APs |
CSCvd48333 | Controller stopped working : emWeb |
CSCvd63242 | Click AP not associating with 11r client in flex connect mode |
CSCux83260 | BGL-Alpha: "lbs-ssc" &" sha256-lbs-ssc" missing in WLC web UI |
CSCva85361 | WLC losing IPv6 Connectivity |
CSCvc41438 | WGB running 15.3(3)JD WGB takes ~500ms longer to scan DFS channels vs JBB |
CSCvb35865 | AP2800 crash for flexconnect-Sensor-Flexconnect |
CSCvc83465 | 8.3MR1: 3800 AP sometime stops sniffing on DFS channel |
CSCva64515 | %SPECTRUM-3-CA_LOGMSG: SPECTRUM LOG: invalid radio type |
CSCvc40267 | WLC sends wrong VLAN for AAA overriden client re-associating to AP belonging to FlexConnect Group |
CSCvc74507 | Fix incorrect commit of CSCuu59589 in 8.0-mr |
CSCvd27065 | EAP-FAST EAP-Chaining on Wired 1810W port does not work |
CSCvd58664 | AP dropping EAP packets on Radio which is seen on Wired uplink |
CSCvd56422 | Error cause 403 generated for 'RFC-3576 Disconnect-Request' |
CSCuz03702 | New mobility:Wired client behind WGB fails to pass traffic after roaming |
CSCva66489 | 11r sess timeout after reassoc causing Deauth 17 mismatch FTIE |
CSCvb94413 | 2800/3800: Fix DAA |
CSCvb97656 | Unexpected reload: Task Name: mmListen on 8.3.102.0 |
CSCvc28168 | WLC set ZERO 802.11e QoS UP for part of the downstream voice packets and APs trust it |
CSCvd06993 | Upgrade to 8.3 requires to reconfigure DNS server IP |
CSCva49263 | 802.11r re-auth failure after roaming |
CSCvb05494 | Wrong format of SNMP trap - mobility flap alarm |
CSCvc09824 | AP2800 band select stats counter show zero |
CSCvc18670 | WLC: Client stops passing traffic on DHCP Reqd. WLAN after sending a Reassoc request but no DHCP pkt |
CSCvc50436 | WGB wired client randomly stuck in the DHCP_REQD state after layer 2 roaming between the controllers |
CSCvc52093 | WLC send deauth 17 to phone in 4-way handshake |
CSCvc65641 | WLC reports tracebacks reported very frequently but no crashes |
CSCvd07215 | AP1810/2800 doesn't learn DHCP lease time from DHCP server and defaults to 24hr. |
CSCvc12566 | New transfer upload command for uploading bundled wlc log files |
Solved! Go to Solution.
06-09-2017 05:59 AM
Still wrong (no radios) data on 1262 APs. Will have to open a TAC case now, sad that it wasn't fixed during beta phase. :(
Edit: My fault - no support for dashboard features with 1262 since they are out of sw support.
