10-20-2016 10:22 AM - edited 07-05-2021 06:00 AM
Hi:
We have a cisco 2504 WLC (8.1.102.0) with 9 AIR-AP2702I-UXK9, with several ssid, I configured one of them to use radio policy 802.11a only (If I set to all clients only connect to 2.4Ghz) . My problem is with this ssid I cannot see it on laptops, iphone, android (of course the can connect to 5Ghz radio), 802.11a/n/ac is up on configuration and I see it enabled on channel 36
Which can be the problem? Any Ideas?
Solved! Go to Solution.
10-20-2016 10:33 AM
Did you prime your APs for the correct country code ? If not 5GHz radio won't come up. Refer below document
Rasika
*** Pls rate all useful responses ***
10-20-2016 10:33 AM
Rasika
10-21-2016 12:14 AM
Great!!! you save my day :-D 5ghz start working
Thanks!!!
10-21-2016 10:22 AM
Glad to hear that. Thanks for rating our responses as well.
Rasika
