802.1a is admin down. wlc 4402 and ap1252
and1hotsauce
Hello all,
I am trying to enable the 802.11a and use the 5Ghz band in my house. However, I am having difficulty in doing this. Please see screenshot below. I have select AU (Australia) as my regulatory domain (2nd image). 802.11a band is enabled(3rd image), but the interface is still down (1st image). Australia regulatory code is -Z. Not sure why -A and -N are showing up
http://i.imgur.com/H3K4wTl.jpg
http://i.imgur.com/KvVzlqJ.jpg
http://i.imgur.com/VR38ZpV.jpg
In the cli, the dot11 radio interface is down. This might be the issue? If so, how would I turn this on from the wlc management page?
http://imgur.com/8g6ikzt
Note: I've tried other regulatory domains - US, US and Mexico, but to no avail.
note 2: now, both radio interfaces are admin down.
Leo Laohoo
Console into the AP and post the output to the command "sh version".
I am suspecting the AP has the regulatory domain of "-A".
Hi Leo,
cisco AIR-LAP1252AG-A-K9   (PowerPC 8349) processor (revision C0) with 49142K/16384K bytes of memory.
Processor board ID FTX14449019
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from reload
LWAPP image version 7.0.250.0
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 58:8D:09:5E:72:4A
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC144102MJ
Top Assembly Part Number             : 800-29536-03
Top Assembly Serial Number           : FTX14449019
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252AG-A-K9
Configuration register is 0xF
Does the A in AIR-LAP1252AG-A-K9, signify the regulatory domain?
I am located in Australia.
If you're in Australia then the Regulatory Domain should be "-N".   And this is the main reason why 802.11a radio is disabled.
