04-05-2021 02:58 PM - edited 07-05-2021 01:05 PM
I've a WLC 8510 version 8.0.140.0 showing linktest packets received just 1, that information is showing for all clients.
(Cisco Controller) >linktest ma:ca:dd:re:ss:20:01
Link Test to ma:ca:dd:re:ss:20:01
Link Test Packets Sent.......................... 20
Link Test Packets Received...................... 2
Local Signal Strength........................... -56dBm
Local Signal to Noise Ratio..................... 37dB
getting "Link Test Packets Received 1 or 2 only for all clients.
04-06-2021 08:49 AM
And do you have any issue other than this link test utility which might also depend on client firewall settings?
04-06-2021 09:02 AM
The issue happens with all devices on the network, IOS, Android and Windows devices.
04-06-2021 10:26 AM
04-06-2021 10:29 AM
Link Test Packets Received is not iqual to Sent
04-06-2021 10:52 AM
Maybe that is normal for that client. I have tested that and some just fail and some are different and some are 20/20. Are you seeing an issue with the clients at all? I have never used that to validate client issues to be honest. I wouldn't worry because, these are pings and initial pings to a device can generate a no response in time.
04-06-2021 11:59 AM
That's not happen with just one client specific, it's happen with android, windows etc.
Maybe it can be related to the controller version 8.0.140.0 or controller time UP.
04-06-2021 01:55 PM
04-06-2021 02:00 PM
Some disconetions, that not seems to be related.
04-06-2021 11:48 PM
Probably not no. For that to troubleshoot we need more information like:
Does it happen to only one client or multiple (different models)?
Only when roaming?
Signal reception good?
Since how long does the problem happen?
Client load balance or Band select features active?
Could you capture a 'debug client macaddressofclient' on the WLC while it's happening and post it here?
04-07-2021 09:30 AM
When you say "not related", so there is really no issues that clients are experiencing? Why not compare with a ping from a laptop or the switch. It has nothing to do with the controller uptime, if you think this issue is with the code you are running, then upgrade it or downgrade it. I'm also assuming this has been running for a long time since you are on a very old code. You might also want to look at the wireless matrix and see what code your ap's support and look at upgrading in the lab or a spare controller to test.
04-07-2021 05:28 PM
Thanks, it seems anyone saw that little bit issue before.
