12-19-2011 08:26 PM - edited 07-03-2021 09:16 PM
Hello!
I have a Cisco 881W that will no longer boot/operate properly if the internal radio card is installed.
If the card is installed, all I get is the following...
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory rommon use
read_sys_eeprom: not a smart eeprom
Search for cpu type (Field ID 0x09) failed.
Using default value...
Search for Controller ID (Field ID 0x40) failed.
C880 platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
rommon 1 >
if I do a dev I get nothing. If I do a dir flash: I get "bad device name". My cookie shows FF in all positions.
BUT......
If I remove the entire WiFi Radio card (both boards), then It boots fine, cookie appears intact, devs appear, IOS loads, just without the WAP.
Any chance this is a matter of a file getting deleted or corrupted or is this certainly bad hardware? The router sans Wifi appears fully functional.
Thanks!
12-20-2011 12:23 AM
You should be able to RMA the device. Search the forum for a post on the limited lifetime warranty:). They explain it good there.
12-20-2011 12:26 AM
https://supportforums.cisco.com/thread/2117128
