9800-40 WLC with 1572 AP in Local Mode not broadcasting SSIDs
toy.thompson
Not sure if anybody has the same issue or if I should open a TAC?
The network includes:
  • 2 x C9800-40-K9 WLCs running Gibraltar 16.2.1 in HA cluster
  • 10 x AIR-AP1572EAC-E-K9 Mesh APs in local mode registered successfully with the WLC
    • 4 x AIR-AP1572EAC-E-K9 APs uses PoE draws power from AIR-PWRINJ1500-2 Power Injectors
    • 6 x AIR-AP1572EAC-E-K9 APs uses PoE draws power from multiple C9300-48UN-A switches
  • 386 x AIR-AP4800-E-K9 APs in local mode registered successfully with the WLC
The AIR-AP4800-E-K9 APs are all working and broadcast all the relevant SSIDs
My problem is the following:
  • None of the AIR-AP1572EAC-E-K9 Mesh APs broadcast any SSIDs, I add them to the same Policy,Site and RF Tags as the AIR-AP4800-E-K9 but they  still don't broadcast any SSID and I cannot associate to any of them
  • None of the 2.4GHz radios on the AIR-AP1572EAC-E-K9 Mesh APs are operational. They have all been enabled and the the 802.11b network have been enabled but the radios on the AIR-AP1572EAC-E-K9 Mesh APs stays DOWN. 2.4GHz radios on the AIR-AP4800-E-K9 are all working.
Not sure if I'm missing something or if I missed a configuration step before I open TAC.
Leo Laohoo
Before contacting TAC, kindly upgrade the firmware to something more recent, say 16.12.3.
Apologies...currently running Gibraltar 16.12.2s
Rafael E
can you share the show tech from one of the affected AP?
what is the power status that the WLC is reporting for those APs
Saludos,
Rafael - TAC
I have managed to resolve the problem. The RF Tag was too long. I created a new shortened one and it resolved both the SSID broadcast problem as well as the 2.4GHz radio down problem. Thanks for the help.
