Dhikra Marghli
Enthusiast
acces point 1130AG problem sauvgarde
Hello
i have acces point 1130AG and i want to configure "  Security: Global SSID Manager"   but i can't save cpnfigure from interface web ap ..
so i can allow AP accept paramter " Security: Global SSID Manager"  that i can see SSID !!
i want ssid: test-wifi  and password: 123456789
but the ap can't accpet the sauvegarde !!
Static WEP Key Option
This setting uses mandatory WEP encryption, no key management and open authentication.
i wait from expert wireless a reply and a help
thanks in advance
3 ACCEPTED SOLUTIONS
Sandeep Choudhary
VIP Mentor
Most if the time...Cisco Autonomosu AP's GUI slow.
bets way is to configure by CLI.
https://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
https://mrncciew.com/2013/03/02/autonomous-ap-with-wpa-psk-security/
Dont forget to rate helpful posts
to delete a ssid:
use this command # no dot11 ssid TOURGUENESS-1 #
use this:
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid sotetel
mbssid > remove it
Dont forget to arte helpful posts
8 REPLIES 8
Dhikra Marghli
Enthusiast
Product/Model Number: AIR-AP1131G-E-K9
Top Assembly Serial Number: FCZ1331Q3FN
System Software Filename: c1130-k9w7-tar.124-3g.JA1
System Software Version: 12.4(3g)JA1
Bootloader Version: 12.3(8)JEA
I send a picture that explain the problem ...
I want to knwo why any think configured that is not saved !!!
Please i wait a reply from expert wirless that help me
Sandeep Choudhary
VIP Mentor
Thanks to reply me and i try used the link 1:
i configure step 1  ok
But in step 2 : it show this error message
ap(config)#interface dot11Radio 0
ap(config-if)#ss
ap(config-if)#ssid sotetel
Dot11Radio0: Guest-ssid already existing on ssid TOURGUENESS-1
ap(config-if)#
so how i can delete this ssid TOURGUENESS-1  with CLI and allow one ssid in AP1130 cisco !!
i wait to reply and thanks in advance
HOW i can delete this scrpit !!! that allow me use only one ssid
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 091D1C5A4D5041455355
thanks in adv
to delete a ssid:
ap#show running-config
Building configuration...
Current configuration : 1393 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$ReXG$gQatPCn01FRR0mIYN2WPI0
no aaa new-model
resource policy
ip subnet-zero
ip domain name ati
ip name-server 193.95.67.22
dot11 ssid sotetel
authentication open
authentication key-management wpa version 2
guest-mode
mbssid guest-mode
wpa-psk ascii 7 135445415F59527D737D
power inline negotiation prestandard source
username Cisco password 7 01300F175804
bridge irb
no ip address
no ip route-cache
ssid sotetel
mbssid
channel 2437
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.5 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap#
I need configure this AP 11300 with ssid sotetel and password 123456789
but SSID is not brodcsat and
ap#show dot11 associations
ap#
so what do you think about configuration !!! what's command that i can add to scrpit !!!
i wait a reply and your help
thanks in adv
use this:
no ip address
no ip route-cache
ssid sotetel
mbssid > remove it
Thank you very much ...you are an excellent expert  wireless in world ...
Content for Community-Ad
