ACL is not working on WLC
Prasan Venky
Level 3
Level 3
Hello All,
I am testing my wireless network. I used some third party tool and found that 443 and 22 ports are still open on the Dynamic Interface IP of the controller.when a guest user gained access and if he tries for the interface IP then it shows the Username: prompt and closing.
Can we restrict it by using ACL..? I tried ACL but no luck.
Any help here..
16666 is the 'mobility' port, it's what the WLC uses to communicate with other members of the Moblity Group.
For the most part, if you haven't enabled management-via-wireless and/or management-via-dynamic-interface you don't really need to worry about it.
The under lying *nix OS is what initialy answers, but the actual application will kill the session.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
8 Replies 8
Stephen Rodriguez
I believe that you need to create a CPU ACL to stop this.
Steve
HTH,
Steve
Many thanks for your reply.
Can u please guide me here how to deny 443 on dynamic int ip ?
Here are some guides that will explane how:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a7c988.shtml
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807810d1.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Omg... I did with it wrongly i guess..
my all access to WLC is gone now. It looks like in the acl i have not permitted any any.
What can i do ..?
reboot, and/or attach to the console port and remove the ACL from the interface and CPU
HTH,
Steve
HTH,
Steve
Yeah... I rebooted it... fortunately i didnt save it.. got access back...thanks for your care...
CPU ACL resolved my previous issue. Now i am not getting 443 and 22 as opened in my tool. but newly two ports 444 and 161113 are shown opened.
How it is .?
HTH,
Steve
HTH,
Steve
I got it Stephen ... Thanks a lot for your time..
