ACS certificate for wireless users.
jmanzur1683
Visitor
Hi.
This is my question.
I have one windows 2008 server, and one cisco ACS 4.2. Its possible if I generate one "Generate Self-Signed Certificate" and install it into the windows 2008 server to authenticate wireless users?
Regads.
Hi Jorge,
Are you  going to  use  Microsft 2008 server as NPS ( radus server) or are you  trying to use ACS as  your radius server.
If you are going to use ACS as your radius server  you can generate self signed cert  on ACS server and use it as your Radius server.
But if you want to  use  Microsft 2008 server as NPS ( radus server)   you may need to find out from Microsft  if your NPS server itself can generate a SSC to work for PEAP.
Cheers,
Srini
