ACS: config. Actice Directory athent.
me
I installed the last version of Cisco ACS 4.0 and I have a problem with the "Windows database configuration". I want to authenticate users on an active directory, but when I want to configure it I have an error message:
"An error has occured while processing the Authen DLL
Default Group Page because of an internal error ..."
I tried to find why I have this error but until now I have nothing that can help me to solve this issue.
Who can help me?
Thanks in advance for any help.
Rui
pradeepde
Level 5
Level 5
You may get this error if the ACS is not correctly installed. Possibly because of some error during installation. Reinstall ACS 4.0 and check if you are getting this error. It should work fine.
