Aeronet APs
nematulla
Can anybody suggest me which Aeronet series Access points r good
Rob Huffman
Hi Nematulla,
This type of question is tough to answer as different AP's are more suitable than others depending on Environment, RF Factors etc. Maybe this will help get you started;
Cisco Aironet Wireless Access Points Solution Overview
http://www.cisco.com/en/US/products/ps6108/prod_brochure0900aecd8035a015.html
We have had good luck with the following AP's;
Cisco Aironet 1130AG Series IEEE 802.11A/B/G Access Point
Low-profile enterprise-class access point with integrated antennas for easy deployment in offices and similar RF environments.
From this doc;
http://www.cisco.com/en/US/products/ps6087/products_data_sheet0900aecd801b9058.html
Cisco Aironet 1230AG Series 802.11A/B/G Access Point
Cisco Aironet 1230AG Series Access Points deliver the versatility, high capacity, security, and enterprise-class features demanded by WLAN customers. These IEEE 802.11a/b/g access points are designed specifically for challenging RF environments such as factories, warehouses, and large retail establishments that require the
antenna versatility associated with connectorized antennas, a rugged metal enclosure, and a broad operating temperature range.
From this doc;
http://www.cisco.com/en/US/products/ps6108/products_data_sheet0900aecd801b9068.html
Cisco Aironet 1240AG Series 802.11A/B/G Access Point
Cisco Aironet 1240AG Series Access Points deliver the versatility, high capacity, security, and enterprise-class features demanded by WLAN customers. These IEEE 802.11a/b/g access points are designed specifically for challenging RF environments such as factories, warehouses, and large retail establishments that require the antenna versatility associated with connectorized antennas, a rugged metal enclosure, and a broad operating temperature range. The Cisco Aironet 1240AG Series provides local as well as inline power, including support for IEEE 802.3af Power over Ethernet (PoE).
From this doc;
http://www.cisco.com/en/US/products/ps6521/products_data_sheet0900aecd8031c844.html
Hope this helps!
Rob
