After 7.0.116.0 Upgrade, Intel WiFi link cards fail
JOHN KELSEY
Beginner
Beginner
Just recently upgrade our 2 5508 controllers from 6.0.199.0 to 7.0.116.0.  Since that upgrade, I have a handful (8 to 10) of wireless laptops that now refuse to associate to any access points.  The thing these laptops all have in common is some variation of the Intel Wifi Link AGN cards.  I have about 200 other clients out there working just fine.
I've tried everything under the sun that I can think of.  Patches, drivers, the whole sh'bang.
Is there a known issue with 7.0.116.0 and these particular cards?  I'm really stumped.
Thanks all!
17 Replies 17
Leo Laohoo
VIP Community Legend VIP Community Legend
Errrr .... How about try the newer 7.0.220.0?
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
That is weird. So do some of the other devices that connect have these same wireless cards or have you isolated the issue to that card?
Sent from my iPhone
-Scott
JOHN KELSEY
Beginner
Beginner
Also now discovered that no Apple Airbooks can connect to the wireless now either.  Weird.
I'll see about going to the 220 code.
Odd, I seen similar behavior. When I enabled fast ssid i noticed the devices would connect .. try that
Make sure client load balancing is disabled on the WLAN SSID advanced tab on the lower right side of the page. This feature doesn't play well with Apple devices and various other laptops.
Sent from my iPhone
-Scott
Surendra BG
Wat does the debug client say??
Surendra BG
thomas03usmcsf
Beginner
Beginner
Do you have Aironet enabled on your SSID?
'Aironet IE' is enabled on the SSID
'Client load balancing' is disabled
I tried the 'fast ssid'...no change.
I've never done a debug client...I have to be on the controller console to do that, right?
Thanks all!
Just the telnet session will do it!! console is not mandatory to run the debug
The debug will be
debug client
Surendra
Surendra BG
thomas03usmcsf
Beginner
Beginner
Try disabling Aironet, let me know if that fixes your issue
The solution turned out to be, disable/enable the b/g/n radios on each controller.  Once we did that, all of the clients could connect again.  So strange.
Thanks to all for the suggestions!
Strange!!
Surendra
Surendra BG
Leo Laohoo
Sounds like CSCto93293 that we discovered and worked with TAC to diagnose.  The notes talk about the 1140 but is present in all AP.  7.0.220.0 fixes
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&from=myNotification&bugId=CSCto93293
Recognize Your Peers
