Can I install one omni and one directional antenna on a single 1562E access point and use the one for 2.4GHz and the other for 5GHz?
Solved! Go to Solution.
Look at THIS picture, particularly the right-hand side. Top ports are for 5 Ghz and the bottom ports are 2.4 Ghz.
Does this answer your question?
One AIR-ANT2547VG-N (omni) and one AIR-ANT2588P3M-N= (directional). I Know, they are both dual band. I will rephrase my question. Can I install both of them on a single 1562E. I need to cover an omni area with the AIR-ANT2547VG-N and a downhill steep path with the AIR-ANT2588P3M-N=. If both work as dual band it will be optimal. It is acceptable though, if one needs to work at 2.4GHz and the other at 5GHz.
Yes, thanks!
