08-31-2022 11:42 PM
Hello Team,
We are using AIR-ANT-2550V-N in a product and the installation of the product is in such a way that the antenna is mounted inverted. Please let us know does the draining hole provided on the antenna needs to be covered when the antenna is mounted in this way.
Best Regards
Manjunath
09-01-2022 02:59 AM
refer below antenna mounting guidance, best always mount the antterna test (out come is more important)
09-08-2022 10:30 PM
