Air-AP1142N-K-K9 compatibles with WLC 2504
Hi, I'm trying to connect AP to WLC
But I think firmware compatible doesn't match.
AP : Air-AP1142N-K-K9
c1140-k9w8-mx.153-3.JC8/c1140-k9w8-xx.153-3.JC8
WLC : WLC 2504
8.2.160.0
Am I have to do upgrade/downgrade of WLC or AP?
If I need to do, where I can find firmware files?
(AP1140 series firmware don't exist on software.cisco.com)
AP can't connect with WLC 2504 - 8.2.160.0 (192.168.1.91)
Dec 7 01:55:34.017: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:509 Certificate verified failed!
Dec 7 01:55:34.017: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.1.91:5246
Dec 7 01:55:34.018: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.91:5246
Dec 7 01:56:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.91 peer_port: 5246
Dec 7 01:56:45.001: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
Dec 7 01:56:45.001: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to 192.168.1.91:5246
Dec 7 01:56:45.001: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.91:5246
Dec 7 01:57:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.91 peer_port: 5246
Dec 7 01:57:58.001: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
Dec 7 01:57:58.001: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to 192.168.1.91:5246
Dec 7 01:57:58.001: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.91:5246
Dec 7 01:58:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.254.200 peer_port: 5246
Dec 7 01:59:18.999: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_connection_db.c:2214 Max retransmission count reached for Connection 0x28F52A0!
2 Accepted Solutions
Sandeep Choudhary
VIP Mentor VIP Mentor
VIP Mentor
Looks like certificate of the access points had expired due to their age.
Please run the below mentioned command on WLC and check again.
WLC#config ap cert-expiry-ignore mic enable
Dont forget to rate helpful posts
Hi, i seem to have a problem like this, i have a 2504 in a lab setup that rejects the 1142 access points though i have a 3702 connected. i did try this conmmand and it did help, but still no good. if anyone has any ideas, i did update the wlc to 8.5. If anyone can see what ive done wrong that be great thanks.
Ap log:
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.0.30.1)
*Sep 2 10:54:18.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.30.109 peer_port: 5246
*Sep 2 10:54:19.430: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.30.109 peer_port: 5246
*Sep 2 10:54:19.430: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.30.109
*Sep 2 10:54:19.433: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.0.30.109
*Sep 2 10:54:19.433: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.30.109:5246
*Sep 2 10:54:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.30.109 peer_port: 5246
*Sep 2 10:54:19.431: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.30.109
*Sep 2 10:54:19.435: %DTLS-5-ALERT: Received WARNING : Close notify alert from 10.0.30.109
*Sep 2 10:54:19.435: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.0.30.109:5246
wlc
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.103.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... CiscoWlc
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.0.30.109
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 35 mins 42 secs
--More-- or (q)uit
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : AU,US
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +33 C
External Temperature............................. +37 C
Fan Status....................................... 3900 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 50:06:04:CA:60:A0
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Time............................................. Fri Sep 2 11:06:08 2022
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 5000
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 168.61.215.74 In Sync AUTH DISABLED
Ap
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.3(3)JD17, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 12-Apr-19 05:21 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA3, RELEASE SOFTWARE (fc1)
cisco AIR-LAP1142N-A-K9 (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FTX1432K16K
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from watchdog timer expired
LWAPP image version 8.3.150.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: F8:66:F2:67:5B:DE
Part Number : 73-11451-08
PCB Serial Number : FOC14300A6J
Top Assembly Part Number : 800-31273-04
Top Assembly Serial Number : FTX1432K16K
Top Revision Number : A0
Product/Model Number : AIR-LAP1142N-A-K9
Leo Laohoo
VIP Community Legend VIP Community Legend
Post the complete output to the following commands:
  1. AP:  sh version
  2. AP:  dir
  3. AP:  sh ip int brief
  4. WLC:  sh sysinfo
  5. WLC:  sh time
Sandeep Choudhary
VIP Mentor
Thanks Sandeep Choudhary !
Problem solved
Ap log:
wlc
--More-- or (q)uit
NTP Servers
Ap
2 802.11 Radios
Recognize Your Peers
