Air-Ap1230B POE Problems
brandoneddings1
I recently had a switch fail.  I decided to upgrade it to a Netgear 802.3af POE Switch.  I figured it would work with my access points since they were using the cisco power injecters (model AIR-PWRINJ2).  For some reason they will not power up using the switch.  Any help would be appreciated.
4DigitCCIE
Pretty sure the 1230s aren't af compliant.  They use either Cisco power or power injectors.
https://supportforums.cisco.com/docs/DOC-4673
-John
