12-26-2010 05:58 AM - edited 07-03-2021 07:35 PM
I have a air-ap1252ag-e-k9 access point, when I plug it in and connect to my network it does not pick up an IP address from the DHCP server. Also the LEDS are producing the following colours:
Ethernet: flashing green
Status: flashing green, red, yellow one after the other
Radio: flashing red fast
Has anyone any ideas what the problem could be, my dhcp server is not picking up the access point which is cabled into my router.
12-26-2010 08:50 AM
Looks like insufficient inline power... please check the below link...
Power up the device using external power supply.. in the mean time make sure the VLAN is mapped to switchport.. also, wat do we see on the console of the device??
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
12-26-2010 09:53 AM
Hello
I already have the access point connected to the external adaptor.........so cannot be a power issue ?
As for your other comments I do not understand as I am a beginner in this area please explain in simpler terms.
thanks
12-26-2010 05:17 PM
ok.. then may be something else.. the second part means.. if you connect to the AP using the console cable (blue colored cable) what do we see?? is the AP in AP: prompt or AP# prompt??
Surendra
