AIR-AP1832I-E-K9 Costume Guest portal
RAJA RAHMAN
HI
Please can some help to get the template for the guest portal in AIR-AP1832I controller.
RR
Sandeep Choudhary
If you are using the newer version like...8.3 then you can customize it.
Here is the attached sample web auth file "Login1":
How to setup : http://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/83/user_guide/b_ME_User_Guide_83/b_ME_User_Guide_83_chapter_0110.html
Dont forget to rate helpful posts
7 Replies 7
Sandeep Choudhary
HI Sandeep ,
as advised i have done  login page
but the logo is not displaying  please can you help
i here attached the file what i have uploaded .The same file i made as tar and uploaded .
RR
I can see the logo in webportal.
you can check by double click on login.html.
HI
When we see the the preview we are seeing like the attached file
change this :
<Center><IMG SRC="yourlogo.jpg" align=bottom center></Center>
still not working then try with another browser!!!!
Tried that too no luck
but when i click in the icon it says image not found
did you try this command:
your logo link must be yourlogo.jpg not png
REgards
