AIR-AP1852I-E-K9 UBI Error - Messed up partitions'
radras
Hi everyone,
We had 2x AIR-AP1852I-E-K9 not in use and connected it to our WLC which worked for one of them.
The 2nd was unable to receive any update of the firmware from WLC and I tried to update the firmware myself.
As inexperience I am, I flashed the partition and even with the loaded firmware via TFTP, I cant load anything nor boot the system.
Factory reset (mode button 20sec) isn't working neither.
Current state of starting the device:
Spoiler
DRAM: 1 GiB
NAND (ONFI): Detected SPANSION S34MS02G1 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:1], write_counter=36
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3af POE or Others detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 0
Specified BOOT: part1
UBI error: ubi_read_volume_table: the layout volume was not found
UBI error: ubi_init: cannot attach mtd2
UBI error: ubi_init: UBI error: cannot initialize UBI, error -22
UBI init error 22
Booting from part1
Error, no UBI device/partition selected!
Booting failed, try boot on part2
Only mode I can access is the "(RNAQ-C7) #" with following commandlist:
Spoiler
(RNAQ-C7) # help
? - alias for 'help'
base - print or set address offset
bootipq - bootipq from flash device
chpart - change active partition
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
echo - echo args to console
env - environment handling commands
ethreg - ethreg - Switch/PHY Reg rd/wr utility
exit - exit script
false - do nothing, unsuccessfully
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
imxtract- extract a part of a multi-image
ipq_nand- Switch between SBL and Linux kernel page layout.
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
nand - NAND sub-system
nm - memory modify (constant address)
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printmfgenv- Print manufacture information data
printshenv- printshenv- print shared environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
saveshenv- saveshenv - save shared environment variables to persistent storage
setenv - set environment variables
setshenv- setshenv - set shared environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
smeminfo- print SMEM FLASH information
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
usb - USB sub-system
verify_bl- Cisco Bootloader signature verify
verify_lx- Cisco Image signature verify
version - print monitor, compiler and linker version
Is there a way to get this back to work? or am I cooked and we have to get a RMA?
Mark Elsen
  - @radras    Type reset , see what happens, if the AP ends up in an error state again then RMA
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Mark, thanks for your answer.
Unfortunately it remains the same after reset. Thanks for letting me know
