09-05-2018 08:26 AM - edited 07-05-2021 09:07 AM
We have an AIR-AP280 that can not be seen by Cisco 5520 Wireless Controller.
Fas 0/1 178 R T AIR-AP280 Gig 0
interface FastEthernet0/1
description cisco AP
switchport access vlan 512
switchport mode access
switchport voice vlan 11
mls qos trust dscp
spanning-tree portfast
spanning-tree bpduguard enable
Vlan512 is up, line protocol is down
Hardware is EtherSVI, address is a0cf.5baf.a7c3 (bia a0cf.5baf.a7c3)
Description: Wireless-MGNT
Internet address is 10.40.12.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 01:11:25, output 01:11:08, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
25897 packets input, 6382358 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
27244 packets output, 1743616 bytes, 0 underruns
0 output errors, 0 interface resets
MPC-MV3-IDF1-QA#show interfaces fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is a0cf.5baf.a783 (bia a0cf.5baf.a783)
Description: cisco AP
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
5 minute input rate 2000 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
605831 packets input, 128264808 bytes, 0 no buffer
Received 601134 broadcasts (570624 multicasts)
0 watchdog, 570624 multicast, 0 pause input
753478 packets output, 62894860 bytes, 0 underruns
Solved! Go to Solution.
09-06-2018 07:19 AM - edited 09-06-2018 07:23 AM
Ok, so the AP is connected to port Fa0/1? Post the complete output to the command "sh cdp n f0/1 det".
Another thing, the interface is "FastEthernet". So I suspect the switch is either a plain 2960 or a plain 3560. This means either model can only support up to 15.4w PoE. This is not enough to power both radios of the AP.
09-06-2018 07:25 AM
09-05-2018 09:14 AM
09-06-2018 07:04 AM
Its there
12 Production active
13 Admin active
14 WLAN active
15 MPLS_Xconnect active
20 VLAN0020 active
21 VLAN0021 active
50 VLAN0050 active
105 VLAN0105 active
120 VLAN0120 active
140 wireless active
150 wireless_Employess active
200 Plant_Equipment active
501 Switch-Management active Gi0/3
502 CCTV active
503 Security active
504 Wireless-Guest active
508 VLAN0508 active
512 Wireless-MGNT active Fa0/1, Gi0/1
VLAN Name Status Ports
513 IT active
514 VLAN0514 active Fa0/2
532 Data-IDF active
536 VLAN0536 active
548 VLAN0548 active
556 VLAN0556
09-06-2018 07:10 AM
version 12.2
no service pad
hostname MPC-MV3-IDF1-QA
boot-start-marker
boot-end-marker
enable secret 5 $1$FU6h$CX2i1Pp1gD3rdVDZGOKcc0
enable password bg4vZknUbiHOUQW5D4bYMPC
username mpcadmin privilege 15 secret 5 $1$FU6h$CX2i1Pp1gD3rdVDZGOKcc0
username admin privilege 15 secret 5 $1$FU6h$CX2i1Pp1gD3rdVDZGOKcc0
username mpcadmim privilege 15 secret 5 $1$0GH7$osrqEIYhUkL8mroi0Nj4J/
aaa new-model
aaa authentication login default group radius local line enable
aaa authentication login no_radius line enable
aaa authentication enable default group radius enable
aaa authorization console
aaa authorization exec default group radius local if-authenticated
aaa authorization exec no_radius none
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa accounting connection default start-stop group radius
aaa session-id common
clock timezone pst -8
clock summer-time PDT recurring
system mtu routing 1500
vtp domain Mariani
vtp mode transparent
authentication mac-move permit
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name mariani.mariani.com
ip dhcp excluded-address 192.168.7.1 192.168.7.50
ip dhcp excluded-address 10.40.11.1 10.40.11.50
ip dhcp excluded-address 10.40.1.1 10.40.1.50
ip dhcp excluded-address 10.40.12.1 10.40.12.50
ip dhcp pool DATA
network 192.168.7.0 255.255.255.0
default-router 192.168.7.1
option 150 ip 10.1.11.20 10.1.11.21
option 43 ip 10.10.12.5
dns-server 10.1.120.15 10.1.12.3
ip dhcp pool VOICE
network 10.40.11.0 255.255.255.0
default-router 10.40.11.1
crypto pki trustpoint TP-self-signed-3746715904
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3746715904
revocation-check none
rsakeypair TP-self-signed-3746715904
crypto pki trustpoint TP-self-signed-3525986560
subject-name cn=IOS-Self-Signed-Certificate-3525986560
rsakeypair TP-self-signed-3525986560
no errdisable detect cause gbic-invalid
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
vlan 10
name Management
vlan 11
name Voice
vlan 12
name Production
vlan 13
name Admin
vlan 14
name WLAN
vlan 15
name MPLS_Xconnect
vlan 20-21,50,105,120
vlan 140
name wireless
vlan 150
name wireless_Employess
vlan 200
name Plant_Equipment
vlan 501
name Switch-Management
vlan 502
name CCTV
vlan 503
name Security
vlan 504
name Wireless-Guest
vlan 508
vlan 512
name Wireless-MGNT
vlan 513
name IT
vlan 514
vlan 532
name Data-IDF
vlan 536,548,556
vlan 580
name Wireless-CORP
vlan 584
name Wireless-Redzone
lldp run
ip ssh version 2
mls qos trust dscp
interface FastEthernet0/2
description ADP Time Clock
switchport access vlan 514
mls qos trust dscp
interface FastEthernet0/3
mls qos trust dscp
interface FastEthernet0/4
mls qos trust dscp
interface FastEthernet0/5
shutdown
mls qos trust dscp
interface FastEthernet0/6
mls qos trust dscp
interface FastEthernet0/7
mls qos trust dscp
interface FastEthernet0/8
mls qos trust dscp
interface FastEthernet0/9
mls qos trust dscp
interface FastEthernet0/10
mls qos trust dscp
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
mls qos trust dscp
interface GigabitEthernet0/2
interface GigabitEthernet0/3
switchport access vlan 501
interface GigabitEthernet0/4
interface Vlan1
ip address 192.168.7.1 255.255.255.0
interface Vlan11
ip address 10.40.11.1 255.255.255.0
interface Vlan501
ip address 10.40.1.1 255.255.255.0
interface Vlan512
description Wireless-MGNT
ip address 10.40.12.1 255.255.255.0
ip helper-address 192.168.7.1
interface Vlan514
ip address 10.40.14.1 255.255.254.0
ip default-gateway 10.40.1.254
ip classless
ip route 0.0.0.0 0.0.0.0 10.40.1.254
ip http server
ip http authentication local
ip http secure-server
ip sla enable reaction-alerts
snmp-server community MarianiNetRO RO
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx root-inconsistency loop-inconsistency
snmp-server host 10.1.100.15 version 2c MarianiNetTrap
radius-server host 10.1.120.17 auth-port 1812 acct-port 1813 key iow&aErTDpdYDpYy%X92qazpGncNEIsVrWCVTjXEeabo1LvbZMU7zlZIV&ZXsPq&
privilege exec level 14 configure
line con 0
session-timeout 15
login authentication defualt
stopbits 1
line vty 0 4
session-timeout 15
transport input ssh
line vty 5 15
session-timeout 15
transport input ssh
end
09-05-2018 03:37 PM
I agree. Is VLAN 512 in the VLAN database?
09-06-2018 07:06 AM
Yes it is in the database
09-06-2018 07:11 AM
Is the power receiving 30w of power ?
09-06-2018 07:18 AM
What is that command
09-06-2018 07:23 AM
sh power inline
"Input power requirements":
● 802.3at power injector (AIR-PWRINJ6=)
09-06-2018 07:24 AM
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto on 15.4 AIR-AP2802E-B-K9 4 15.4
Fa0/2 auto on 15.4 Ieee PD 4 15.4
Fa0/3 auto on 6.3 IP Phone 8811 2 15.4
Fa0/4 auto off 0.0 n/a n/a 15.4
Fa0/5 auto off 0.0 n/a n/a 15.4
Fa0/6 auto off 0.0 n/a n/a 15.4
Fa0/7 auto off 0.0 n/a n/a 15.4
Fa0/8 auto off 0.0 n/a n/a 15.4
Fa0/9 auto off 0.0 n/a n/a 15.4
Fa0/10 auto off 0.0 n/a n/a 15.4
Fa0/11 auto off 0.0 n/a n/a 15.4
Fa0/12 auto off 0.0 n/a n/a 15.4
Fa0/13 auto off 0.0 n/a n/a 15.4
Fa0/14 auto off 0.0 n/a n/a 15.4
Fa0/15 auto off 0.0 n/a n/a 15.4
Fa0/16 auto off 0.0 n/a n/a 15.4
Fa0/17 auto off 0.0 n/a n/a 15.4
Fa0/18 auto off 0.0 n/a n/a 15.4
Fa0/19 auto off 0.0 n/a n/a 15.4
09-06-2018 07:25 AM
09-06-2018 07:29 AM
@kopur1991 wrote:
I think this is the issue, it is only receiving 15.4w, it needs poe+ (30w).
I got 4 x 2800 which are running on 15.4w and it can join the WLC. This is not the cause of the issue of the AP not joining the WLC. Something else is missing from the information provided.
09-06-2018 07:45 AM
Thanks for correcting me Leo 🙂
09-06-2018 07:49 AM
ks everonei am going to replace the switch at this poing
