No, you won't really see any benefit for an office space. The antenna you would use in there is very similar gain and pattern wise to the internal antenna.
When they are refferencing challenging environments, they are speaking of places where you need really high gain antenna, or the need for patch antennas to direct the pattern better.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
