05-15-2017 09:13 PM - edited 07-05-2021 07:02 AM
Hi Experts,
We have installed 1 unit 2504 WLC and 3 unit RAP. All RAP configured with the same configuration and tested before a
All RAP configured and done tested, all joined WLC.
After a year, I power up the WLC and RAP once installed at
Already check for a port on switch, cable and found no issue with that.
Attached is the WLC config with all RAP config.
Kindly help me on this issue.
Thanks.
Best Regards,
Hanif
05-15-2017 09:21 PM
The 1550 is an outdoor AP. All outdoor AP's require the Ethernet MAC address to be entered into the controller. Look for the Mac on the label and enter it on the controller Mac filter and the AP will join.
-Scott
05-15-2017 09:25 PM
This has nothing to do with the AP joining, However, you should look at getting off the v8.0 code and look at v8.2.151.0. We had soooooo many issue with v8.0 and any v8.2 was better:)
-Scott
05-16-2017 11:23 PM
Dear Scott,
Thanks for your response.
I already perform the MAC Filter at the WLC.
Another 2 RAP is joined, but this one RAP not joined.
Really need to update the v8.2? because another joined RAP use
Really not understand this kind of issue.
Kindly help to guide me
Thanks.
Hanif
05-16-2017 11:53 PM
v8.2 was just informative and will not help you here. So you have two other RAP's up and the third one isn't coming up. Have you looked at the switchport configuration and make sure that the cable is okay? I always connect the outdoor AP's to the controller first by putting them on the same vlan as the controller. If you are using static and the AP for some reason doesn't join, on the output in the console, you will see the AP requesting a dhcp. I think the best thing to do right now is verify the switchport configuration, make sure the cable is okay and place the AP on the same subnet. Connect a console to the AP and power cycle the unit.
-Scott
05-19-2017 10:51 PM
Dear Scott,
Thanks for your email.
I already perform as per you said. But it still not able to join WLC.
If AP connected to switch, we still able to see the MAC address even
I perform command ''show
Thanks for your support.
Hanif
05-16-2017 03:24 AM
I don't see signs that the AP got a valid IP address.
05-16-2017 11:19 PM
Hi Leo,
We already set the static IP. We use IP 10.51.14.13 for this AP.
WLC use 10.51.14.11.
Is it that true configured right?
interface BVI1 mac-address 381c.1a22.5be0 ip address 10.51.14.13 255.255.255.0
Thanks and best regards,
Hanif Saharudin
