andris87
Beginner
AIR-CAP26021I-A-K9 wifi improvement
hi,
i'm posting screenshots of my wifi config and i'd like to know if there are other settings to improve my AP 2600i wireless connection.
i have a fiber connection of 1 Gbps (with ethernet cable cat 7 25mt i see in ookla speed test 978mbps!
with the modem/routr/ap of my operator i can go to 200mbps in 2.4 ghz, using the AP now i'm under 50mbps....
in my room i can't use 5ghz because the signal is too low (before with my carrier modem/routr/ap i did at 150 mbps)
i installed and configured this ap because with last firmware update my modem/routr/ap has become instable in wifi connection (i was losing connection every 5 min).
now ,with ap on 1gbps ethernet using a short cat5 cable, i loos too much in velocity, is it normal?
Immagine 2022-05-19 210515.jpgImmagine 2022-05-19 210603.jpgImmagine 2022-05-19 210644.jpgImmagine 2022-05-19 210745.jpgImmagine 2022-05-19 210815.jpg
thank you for your advices
4 REPLIES 4
Leo Laohoo
VIP Community Legend
Data Rates (both radios):  Disable everything from 1- to 11 Mbps.  Make 18-, 36- & 54 Mandatory and the rest are Supported.
Disable 2.4 Ghz if all the clients can support 5.0 Ghz.
hi leo, i tried but with yours indications i haven't improvements....my pc doesn't reach this ap in 5ghz, but it does the old one....a little poor this Cisco device....
Leo Laohoo
Does the PC even have 5.0 Ghz radio?
yes it has but it is too "far" and the signal is low to have a stable connection, but the problem are the wifi standards of this ap: a-b-g so it doesn't go faster than 54mbps....a gigabit fiber connection under a 54mbps ap (2,4ghz)....bad choice
Create
Recognize Your Peers
Content for Community-Ad
