AIR-CAP3502I-A-K9 | Mar 19 03:35:36.011: %PKI-3-CERTIFICATE_INVALID_EX
Ibrahim Jamil
Level 6
Level 6
Hi Guys
I m getting the Below for this AP Product/Model Number : AIR-CAP3502I-A-K9
it Does Works/Joined WLC after i changed the WLC-2504 clock time to 1 March 2022 but the Radio of the APs keeps up and Down , how to i fix that issue??
thanks
*Mar 19 03:35:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.105 peer_port: 5246
*Mar 19 03:35:36.011: %PKI-3-CERTIFICATE_INVALID_EXPIRED: Certificate chain validation has failed. The certificate (SN: 4C977E00000008D0D0) has expired. Validity period ended on 01:01:55 UTC Mar 16 2022Peer certificate verification failed 001A
*Mar 19 03:35:36.011: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:509 Certificate verified failed!
*Mar 19 03:35:36.011: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.100.105:5246
*Mar 19 03:35:36.011: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.105:5246
*Mar 19 03:36:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.105 peer_port: 5246
*Mar 19 03:36:45.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
*Mar 19 03:36:45.000: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to 192.168.100.105:5246
*Mar 19 03:36:45.000: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.105:5246
User Access Verification
Username:
Username:
Password:
*Mar 19 03:37:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.105 peer_port: 5246
*Mar 19 03:37:52.000: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
*Mar 19 03:37:52.000: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to 192.168.100.105:5246
*Mar 19 03:37:52.000: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.105:5246
% Authentication failed
Username: Cisco
Password:
AP>
AP>
AP>
AP>
AP>
AP>
AP>en
Password:
% Access denied
AP>
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar 19 03:39:03.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.105 peer_port: 5246
*Mar 19 03:39:03.009: %PKI-3-CERTIFICATE_INVALID_EXPIRED: Certificate chain validation has failed. The certificate (SN: 4C977E00000008D0D0) has expired. Validity period ended on 01:01:55 UTC Mar 16 2022Peer certificate verification failed 001A
*Mar 19 03:39:03.009: DTLS_CLIENT_ERROR: ../capwap/base_capwap/capwap/base_capwap_wtp_dtls.c:509 Certificate verified failed!
*Mar 19 03:39:03.009: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 192.168.100.105:5246
*Mar 19 03:39:03.009: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.105:5246
AP>
AP>
10 Replies 10
Leo Laohoo
Post the complete output to the WLC command of "sh sysinfo".
Hello Leo
Here you go my freind
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.110.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.100.105
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 2 mins 35 secs
--More-- or (q)uit
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +11 C
External Temperature............................. +15 C
Fan Status....................................... 3500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 40:C4:AA:BB:CC:00
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
AP_CLI#show crypto pki certificates
CA Certificate
Status: Available...
Certificate
Status: Available
Certificate Serial Number: 728AF4350000001E4C89
Certificate Usage: General Purpose
Issuer:
cn=Cisco Manufacturing CA
o=Cisco Systems
Subject:
ea=support@cisco.com
cn=C1130-001c58b5b3a4
o=Cisco Systems
l=San Jose
st=California
c=US
CRL Distribution Points:
http://www.cisco.com/security/crl/cmca.crl
Validity Date:
start date: 04:22:10 UTC Jul 11 2007
end date: 04:32:10 UTC Jul 11 2017
Associated Trustpoints: Cisco_IOS_MIC_cert
check the date if it end then, config NTP to be before that Date and it will join.
other workaround is
config ap cert-expiry-ignore {mic|ssc} enable
Hi MHM
I played with time to be 2 weeks Back , but the Wireless IP-Phone (7921) no longer able to register to CUCM 11.5 SU10 :((( coz AP Radio keeps up and down while AP joined the WLC
Did you try cert ignore?
Upgrade the firmware.
Hello leo My Freind
Shall i go with below version
AIR-CTVM-K9-8-10-171-0.aes
thanks
Shall i go with below version AIR-CTVM-K9-8-10-171-0.aes
No because the last train to support 3500 is 8.5.X.X.
Rich R
And make sure you have read and carefully followed all the steps in https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
Refer to https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html for latest build of AireOS you should be using subject to support for all your APs.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ctr-ap_support
Thanks rrudling
