03-09-2013 07:17 PM - edited 07-03-2021 11:42 PM
Hi All,
I have a question regarding to AIR-CAP3602I-A-K9. May I know does AIR-CAP3602I-A-K9 has the 802.11a module? Since I configured it with vWLC, I haven't AIR-CAP3602I-A-K9 inside 802.11a/n?
If so, any module I need to purchase to enable 5GHz.
vWLC version: 7.3.112.0
AIR-CAP3602I-A-K9 version: 7.3.112.0
Many Thanks!
hang
Solved! Go to Solution.
03-09-2013 07:56 PM
Change Country Setting to "US"?
It will work, somewhat but I personally (and professionally) don't recommend because you are breaking the law of the land.
Talk the the local Cisco SE and have them replace the AP with the correct regulatory domain.
03-09-2013 07:23 PM
Can you post the following commands:
1. vWLC: sh sysinfo;
2. AP: sh version;
3. AP: sh inventory; and
4. AP: dir
03-09-2013 07:29 PM
Please help to below info.
1. vWLC sh sysinfo:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.112.0
RTOS Version..................................... 7.3.112.0
Bootloader Version............................... 7.3.101.0
Emergency Image Version.......................... 7.3.101.0
Build Type....................................... DATA + WPS
System Name...................................... IHT-CWLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.0.10.12
System Up Time................................... 6 days 16 hrs 54 mins 29 secs
System Timezone Location......................... (GMT +8:00) HongKong, Bejing, Chongquing
Configured Country............................... HK - Hong Kong
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 3
Burned-in MAC Address............................ 00:50:56:BE:14:A6
Maximum number of APs supported.................. 5
2. AP sh version:
AP#sh ver
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(2)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 23-Jan-13 10:30 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(23c)JY, RELEASE SOFTWARE (fc1)
AP uptime is 18 hours, 18 minutes
System image file is "flash:/ap3g2-k9w8-mx.152-2.JA1/ap3g2-k9w8-xx.152-2.JA1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-CAP3602I-A-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FTX1636R0CU
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.3.112.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 30:F7:0D:D3:94:14
Part Number : 73-14521-02
PCA Assembly Number : 800-37501-02
PCA Revision Number : A0
PCB Serial Number :
Top Assembly Part Number : 800-35852-02
Top Assembly Serial Number :
Top Revision Number : C0
Product/Model Number : AIR-CAP3602I-A-K9
Configuration register is 0xF
3. AP sh inventory:
AP#sh inventory
NAME: "AP3600", DESCR: "Cisco Aironet 3600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP3602I-A-K9 , VID: V01, SN:
4. AP dir:
AP#dir
Directory of flash:/
2 -rwx 965 Mar 9 2013 09:06:18 +00:00 lwapp_mm_mwar_hash.cfg
3 drwx 0 Mar 1 1993 00:00:46 +00:00 configs
4 -rwx 265 Mar 9 2013 09:25:55 +00:00 lwapp_mobileconcierge.cfg
5 -rwx 67202 Feb 19 2013 12:30:38 +00:00 event.log
12 drwx 832 Feb 19 2013 12:25:30 +00:00 ap3g2-k9w8-mx.152-2.JA1
6 -rwx 29996 Mar 9 2013 18:34:47 +00:00 lwapp_non_apspecific_reap.cfg
7 -rwx 64 Mar 1 1993 00:00:29 +00:00 sensord_CSPRNG0
8 -rwx 64 Mar 1 1993 00:00:41 +00:00 sensord_CSPRNG1
9 -rwx 95008 Mar 9 2013 09:06:24 +00:00 lwapp_reap.cfg
10 -rwx 280 Mar 9 2013 09:06:18 +00:00 lwapp_officeextend.cfg
11 -rwx 7192 Mar 9 2013 18:34:46 +00:00 private-multiple-fs
49 -rwx 333 Mar 9 2013 09:06:17 +00:00 env_vars
Many Thanks
03-09-2013 07:42 PM
Here's the reason why.
The AP has the wrong Regulatory Coompliance. You should be using "-N".
03-09-2013 07:44 PM
May I know how can I fix this issue?
Many Thanks!
03-09-2013 07:56 PM
03-09-2013 08:14 PM
Thanks for your help!
I updated the vWLC software to 7.4.100, the "-A" regular seems to be removed. 5GHz appear again and which country code haven't changed.
Many Thanks!
03-09-2013 08:23 PM
Ok, that's wierd.
I have a few APs that were incorrectly delivered to us and they are "-A" and the 802.11a/n radios won't come up because I need my APs need to have, like you, "-N".
