11-11-2017 06:55 AM - edited 07-05-2021 07:51 AM
Hello everyone,
i got 8 cisco ap's from our companies it admin he dosen't need anymore...
Is there an easy and low cost way how i could use these ap's for my home network including a working wifi handover.
thanks for any information!
best regards Max
11-11-2017 08:28 AM
11-21-2017 02:00 AM
thanks for ur reply.
im not sure if i am able to get the autonomous image. Till i meet our it person again it will take a while...
However maybe there will another solution to this.
So far i have Ethernet Cable's in each room of the house. My plan was to buy a small poE Switch with around 8 ports. Minimum i would like to install 4 AP's maximum 8.
When the AP's operate in autonomous mode, are they still able to do a wifi roaming?
