AIR-CAP702I-E-K9
Ziad Mohsen
hello,
the ssid is hidden on my AP AIR-CAP702I-E-K9, can any one tell me how to make it visible.
thank you
Haydn Andrews
If the AP is being managed from a controller.
 WLANs tick the box broadcast SSID enabled.
If you have an autonomous mode AP then:
you need command:
mbssid guest-mode - if you have multiple SSIDs or ssid guest-mode in the dot11 ssid  config part
*****Help out other by using the rating system and marking answered questions as "Answered"*****
can you please help me further i'm still new to cisco APs, and i done't have a controller, can you tell me where to put the commaned
also i have attached screen shots to my ssid manager page if it well help.
If you are single ssid on AP then do these:
Conf ter
Dot11 ssid <SSID name>
Guest-mode
Dont forget to rate helpful posts
If its only a single SSID your trying to do.
On Capture 4.
Where it says Set Single Guest Mode SSID and the drop down box is <None> change that to your SSID
otherwise on capture 3. Under multiple BSSID Beacon Settings:
Tick Set SSID as Guest Mode then in capture 4 for the set beacon select Multiple BSSID.
