11-07-2013 06:00 PM - edited 07-04-2021 01:14 AM
Hello to all,
I am doing an new wireless lan deployment.
i configured all the switchces and WLAN controller as per document.
When I tried to connect the AP to associate with the WLC, I am getting the error below.
Ping communication between the AP and the WLC is fine.
I am getting the error below from the AP:
*Apr 21 14:15:20.039: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'PRJ-WLC01'running version 7.0.220.0 is rejected.
*Apr 21 14:15:20.039: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Apr 21 14:15:20.039: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Apr 21 14:15:20.039: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Apr 21 14:15:20.039: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 192.168.200.10
Pls let me know if you need additional information.
Thanks in advance.
Solved! Go to Solution.
11-07-2013 06:13 PM
1. Upgrade the firmware of your WLC to 7.1.91.0.
Software Release Support for Access Points
Apr 21 14:15:20.039
2. Make sure the time and date of the WLC is correct or synchronized to a valid time source.
11-07-2013 06:13 PM
Apr 21 14:15:20.039
