AIR-CTVM-K9 - Somme Client unable to connect to PSK SSID
LAN team
Since few weeks, most of the client are unable to connect to a PSK SSID.
On logs, we can see :  Received EAPOL-key M2 with invalid MIC from mobile xx:xx:xx:xx:xx:xx version 2 while it's valid MIC received on the few working client.
is it a bug ?
3 Accepted Solutions
Only make user correctly enter password
MHM
believe me it issue of password
(Cisco Controller) >show client detail xx.xx.xx.xx
 do this and share output
ans ask IT to re enter the password
MHM
@LAN team
 It can be a bug if no config was change but before, run a debug and share the logs please
  • debug client client_mac, where client _mac is the MAC address of the client's test.
  • debug aaa detail enable
 This message suggest wrong password.
12 Replies 12
MHM
On-site guy confirm it has been verified.
MHM
marce1000
           - What software version is the controller running ?
 M.
It's 8.5.161.6
  - You should go for https://software.cisco.com/download/home/284464214/type/280926587/release/8.10.196.0
     to have the latest bugfixes and because the aireos based platforms are getting obsolete.
  M.
Before updating to 8.10 check that your APs are compatible with 8.10 on the Compatibility Matrix (link below).
If not then you should, at the very least update, to 8.5.182.12 (link below).
That kind of problem could also be a bug in the client so check that clients' OS and drivers are up to date.
What type of clients are affected and have they recently had any updates?
@LAN team
LAN team
Finaly, you're right. on site team confirm it was a password issue...sorry guys.
@LAN team  So did the PSK on the devices get pushed out wrong or did users use the wrong PSK? It's weird that you mentioned most of the devices started to fail.
-Scott
LAN team
Don't know exactly as information are provided by on site team...
@LAN team, You can't start to troubleshoot without proper data.  You need to see it for yourself... I was on a call yesterday because a device wan't able to connect.  We use MAB along with iPSK and the vendor was providing an ethernet mac address which was not in our DB to auth.  Until I asked for a screen shot, then I noticed they were providing the ethernet mac and not the wireless mac.  I have also had folks fat finger the PSK.  So again... verify first.
-Scott
