AIR-LAP1041N-E-K9 Dot11Radio0 reset, does not go up
vladakoci
I do have several AIR-LAP1041N-E-K9 APs joined AIR-CT8510-K9 running 7.6.130.0 in Flexconnect mode. These APs were used in Local mode on an older controller before.
I had an issue that the APs were in Admin disable when they reloaded. I had to enable manually. I wanted to get rid of it and cleared them to factory defaults ( GUI/ClearAllConfig ) and have them configured from the scratch.
Admin disable issue disappeared, but there is now another problem, even worse. Dot11Radio0  is in reset and cannot bring it up
Dot11Radio0                unassigned      NO  unset  reset                 down
AP log sequence is:
*Mar  1 00:08:22.170: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:08:22.392: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:08:38.974: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
Tried couple of things, played with PoE settings on the switch, tried to use recovery image on the AP, and others,  but nothing helped.
Does anyone have an idea what could help?
Many thanks,
Vlad
8 Replies 8
Leo Laohoo
I am suspecting the AP has the wrong Regulatory Domain.
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time
Thanks, show sysinfo and showtime below.
I tried:
  • Changed the mode from flexconnect to local on one AP on the same controller, Radio is on and the AP works fine.
  • Moved one other AP from this controller  to another running 7.6.120.0, using completely different WLAN and Flexconnect groups, and have the same problem.
I guess it is not related to Regulatory Domain. The Radio is reset before the AP joins the controller ( reading that from the AP log ). I do not know if this is normal behaviour or not.
There are only these two Interface Dot11Radio0 status change  messages in the AP log, they appear before the AP joins the controller.
(Ctrl1) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
RTOS Version..................................... 7.6.130.0
Bootloader Version............................... 8.0.100.0
Emergency Image Version.......................... 8.0.100.0
Build Type....................................... DATA + WPS
System Name...................................... Ctrl1
System Location.................................. Loca
System Contact................................... IT
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. Disabled
IP Address....................................... 1.1.1.1
System Up Time................................... 26 days 23 hrs 51 mins 43 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries:CN,CZ,HK,JP,KR
--More-- or (q)uit
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +24 C
Fan Status....................................... OK
                                                    RAID Volume Status
Drive 0.......................................... Good
Drive 1.......................................... Good
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 20
Number of Active Clients......................... 254
Burned-in MAC Address............................ 10:05:CA:BE:ED:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 300
(Ctrl1) >showtime
Incorrect usage.  Use the '?' or <TAB> key to list commands.
(Ctrl1) >show time
Time............................................. Fri Aug  7 11:33:42 2015
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
    NTP Polling Interval.........................     3600
     Index     NTP Key Index                  NTP Server                  NTP Msg Auth Status
       1              0                                10.128.39.21       AUTH DISABLED*
       2              0                                10.128.39.22       AUTH DISABLED*
(Ctrl1) >
As suspected, the radio is in "disabled" state because the regulatory domain of the AP is "-E" but the controller has numerous country codes which have conflicting regulatory domain.
Thanks.
Not sure what that means. I have plenty of other controllers with many country codes configured and many APs with many regulatory domains ( placed in many countries worldwide ). What's conflicting?
The radio is not disabled, but is reset. I think this is suspicious. It is reset before the AP joins controller.
Ok, if the radio is in "reset" stage, post the following output:
1.  Command:  dir flash:
2.  Reboot the AP and post the entire boot-up process.
Unfortunately I do not have the console available so cannot see the boot process, but I will have next week and will provide.
AP#dir flash:
Directory of flash:/
   44  drwx         704   Aug 7 2015 10:47:53 +00:00  c1140-k9w8-mx.152-4.JB6
    3  drwx         128  Jul 29 2015 09:05:38 +00:00  configs
    4  -rwx       95008   Aug 7 2015 11:19:24 +00:00  lwapp_reap.cfg.bak
    5  -rwx       35488   Aug 7 2015 11:19:56 +00:00  lwapp_non_apspecific_reap.cfg
    6  -rwx         280   Aug 7 2015 11:19:20 +00:00  lwapp_officeextend.cfg
    7  drwx         128   Mar 1 2002 00:07:42 +00:00  c1140-rcvk9w8-mx
   37  -rwx       73119   Aug 7 2015 11:16:10 +00:00  event.log
   11  -rwx        7192   Aug 7 2015 11:19:25 +00:00  private-multiple-fs
   12  -rwx       95008   Aug 7 2015 11:19:56 +00:00  lwapp_reap.cfg
   14  -rwx       76247   Aug 7 2015 08:23:58 +00:00  event.capwap
   16  -rwx         267   Aug 7 2015 11:19:18 +00:00  env_vars
32126976 bytes total (14773248 bytes free)
I tried to change admin status of 2.4 Radio to to Disable through GUI and then back to Enable.
Can see the messages on AP:
*Aug  7 12:18:10.277: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Aug  7 12:18:18.512: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
And this on the controller ( have debug for AP enabled )
(Ctrl1) >*spamApTask7: Aug 07 14:21:04.643: 58:97:1e:23:50:d0 AP: *Aug  7 12:21:02.052: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*spamApTask7: Aug 07 14:21:24.021: 58:97:1e:23:50:d0 AP: *Aug  7 12:21:20.977: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
It seems there is a confirmed firmware bug for this AP model and 7.6.xxx OS versions.
