03-05-2012 08:06 AM - edited 07-03-2021 09:43 PM
hello,
I have a air-lap1042-n-e-k9, how to put this wi-fi mode autonomous ?
03-05-2012 08:21 AM
03-05-2012 11:47 AM
03-05-2012 01:27 PM
I use a POE switch, because I don't external power ...
Same thing. You can disconnect the ethernet cable to power off the WAP or you can use the command in the interface-level "no power inline" or "power inline never" to disable power to the port.
03-06-2012 04:27 AM
I did as in the link but its not working ...
Can you give me more explication.
03-07-2012 01:19 PM
1. Connect the WAP into, say, port 1 of the Cisco switch.
2. Connect the TFTP server to say, port 2 on the Cisco switch.
3. Make sure they are on the same VLAN, VLAN 1, for example.
4. In the switch, configure this:
conf t
interface f0/1
power inline never
5. Hold down the WAP's "mode" button
6. Back to the switch, enter the command: no power inline never
7. Keep holding the mode button until it'll say something like "waiting for the mode button to be released" or something.
