AIR-LAP1242AG-A-K9 Cannot Join to WLC
arika_wahyono
Beginner
Beginner
Guys,
I have problem, i try to connect AP AIR-LAP1242AG-A-K9 to WLC 4400 with Software 7.0.98.218, but the AP indicator is blink and always request new IP addres (based on AP logg console), this device can ping from LAN but unstable (based on logg, the AP always request new IP Address).
anyone have any had same experience with this case?
This is log when i try console to AP.
Xmodem file system is available.
flashfs[0]: 15 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 10084864
flashfs[0]: Bytes available: 5914112
flashfs[0]: flashfs fsck took 36 seconds.
Base ethernet MAC Address: 00:1d:45:36:86:ca
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JZ, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 06-Apr-11 15:01 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 15 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 10084864
flashfs[1]: Bytes available: 5656064
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory.
Processor board ID FTX1135B3ZF
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.98.218
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: xxxxxxxxxx
Part Number                          : 73-9925-06
PCA Assembly Number                  : 800-26579-05
PCA Revision Number                  : xxxxx
PCB Serial Number                    : xxxxxxx
Top Assembly Part Number             : xxxxxxx
Top Assembly Serial Number           : xxxxxxx
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:06.526: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.150: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.747: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.863: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.895:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.004: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.072: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.072: %SNMP-5-COLDSTART: SNMP agent on host AP001d.4536.86ca is undergoing a cold start
*Mar  1 00:00:12.154: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:12.369: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:13.016: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:20.493: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:00:30.976:  status of voice_diag_test from WLC is false
*Mar  1 00:00:31.083: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:34.263: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:34.304: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:34.342: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:35.265: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:35.265: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:35.304: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.tester.net"...domain server (10.10.10.40)
Translating "CISCO-LWAPP-CONTROLLER.tester.net"...domain server (10.10.10.40)
*Mar  1 00:00:42.131: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:42.135: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:00:42.139: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:01:32.143: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:01:34.274: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Not in Bound state.
*Mar  1 00:01:40.659: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:01:40.778: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:01:48.652: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:48.655: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:01:48.657: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:02:28.661: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:02:37.173: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:37.290: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxx.xxxx
*Mar  1 00:02:45.164: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:45.167: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:02:45.169: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:03:25.170: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:03:33.681: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:33.798: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:03:41.673: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:41.676: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:03:41.678: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:04:21.679: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:04:30.191: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:04:30.308: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:04:38.181: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:04:38.184: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:04:38.187: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:05:18.191: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:05:26.703: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:05:26.820: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:05:34.694: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:05:34.696: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:05:34.699: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROL
Thanks!!!
30 Replies 30
Hi Sandeep,
So, what do you want me to do?
to change the timezone on WLC? i cant do that because will impact to network.
and with AP, that i know we cant change that, or do you have any idea to change the timezone on AP?
Arik
This shows that the AP has not been reset:
%DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address x.x.x.x, mask 255.255.255.0, hostname TEST
You should see the default hostname of the AP which is AP
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Leo Laohoo
VIP Community Legend VIP Community Legend
Scott,
I think there is a firewall somewhere.
Hi Leo,
No firewall,
Thxs,
Arik
Hi Scott,
Before you said to factory default, i had been reset the AP, yes the hostname is the mac-address,
but to make sure i had to reset again and capture it,
this is the capture:
TEST#Xmodem file system is available.
flashfs[0]: 13 files, 4 directories
flashfs[0]: Bytes used: 10060800
flashfs[0]: Bytes available: 5938176
flashfs[0]: flashfs fsck took 39 seconds.
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
button is pressed, wait for button to be released...
button pressed for 173 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
ap:  delete flash:private-config
Are you sure you want to delete "flash:private-config" (y/n)?y
File "flash:private-config" not deleted -- no such file or directory
ap: delete flash:private-multiple-fs
Are you sure you want to delete "flash:private-multiple-fs" (y/n)?y
File "flash:private-multiple-fs" deleted
ap:
ap: boot
Loading "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"...##################################################################################################################################################################################################
File "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
           cisco Systems, Inc.
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(10b)JDA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 30-Oct-08 12:05 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x003C24A0
flashfs[1]: 12 files, 4 directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 10059776
flashfs[1]: Bytes available: 5939200
flashfs[1]: flashfs fsck took 4 seconds.
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID xxxxxF
LWAPP image version 3.0.51.0
Base ethernet MAC Address: 00:1D:45:36:86:CA
PCA Revision Number                  : A0
Top Assembly Part Number             : 800-29151-02
The name for the keys will be: ap.cisco.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
ip ssh version 2
% Invalid input detected at '^' marker.
transport input ssh
aaa new-model
aaa authentication login default enable local none
o
*Mar  1 00:00:08.205: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:09.232: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Mar  1 00:00:09.635: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:16.375: %SYS-5-RESTART: System restarted --
transport input ssh
logging origin-id string AP:001d.4536.86ca
logging 255.255.255.255
logging trap 3
*Mar  1 00:00:27.393: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:27.882: Logging LWAPP message to 255.255.255.255.
TEST>
Arik
Hmmmm ... LWAPP.
Post the following output:
1.  sh ip int brief;
2.  sh inventory
If the AP can ping the 4404, the what happens if you enter this command "lwapp ap controller ip address "?
Product Version.................................. 7.0.98.218
RTOS Version..................................... 7.0.98.218
Bootloader Version............................... 4.0.206.0
And upgrade your firmware to 7.0.250.X.  Don't forget to upgrade the bootstrap too.
Dear Team,
My AP has associate with the wlc, all i do is reset and reset AP to factory default, and then i assign static ip address and now the AP has discover from wlc and then i change the static to dhcp and everything going normally.
this step has been done before but failed.
Thanks for support!!
Arik
You mean this AP has joined a WLC before?  If so, then how come the AP is booting up the "RCV" file now?
Dear Leo,
I mean, i had reset the AP and assign static ip address before but still AP still cant associate to wlc.
and dont know why, this step is work now.
Arik
Ahhh ... Ok.  So problem solved?
yes Leo.
Sandeep Choudhary
VIP Mentor VIP Mentor
VIP Mentor
HI Arika,
First of all paste the output of these commands:
From WLC: sh sysinfo
From AP: sh version
Not in Bound state.
as per this error AP not able to find WLC. makse sure that atleast one method is avilable for AP to findout the AP, either broadcats or DHCP 43 option.
Dont forget to rate helpful posts
Naveen Kumar
Enthusiast
Enthusiast
So are you saying it works when you put a static address but not when you have the ap setup for dhcp?
Abha Jha
Try with the static IP as of the WLC management interface.
From this line:-
Not in Bound state.
it seems AP is not able to join WLC with the IP address it gets assigned from the DHCP.
Recognize Your Peers
