AIR-LAP1242AG-A-K9 Cannot Join to WLC
arika_wahyono
Beginner
Beginner
Guys,
I have problem, i try to connect AP AIR-LAP1242AG-A-K9 to WLC 4400 with Software 7.0.98.218, but the AP indicator is blink and always request new IP addres (based on AP logg console), this device can ping from LAN but unstable (based on logg, the AP always request new IP Address).
anyone have any had same experience with this case?
This is log when i try console to AP.
Xmodem file system is available.
flashfs[0]: 15 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 10084864
flashfs[0]: Bytes available: 5914112
flashfs[0]: flashfs fsck took 36 seconds.
Base ethernet MAC Address: 00:1d:45:36:86:ca
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JZ, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 06-Apr-11 15:01 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 15 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 10084864
flashfs[1]: Bytes available: 5656064
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory.
Processor board ID FTX1135B3ZF
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.98.218
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: xxxxxxxxxx
Part Number                          : 73-9925-06
PCA Assembly Number                  : 800-26579-05
PCA Revision Number                  : xxxxx
PCB Serial Number                    : xxxxxxx
Top Assembly Part Number             : xxxxxxx
Top Assembly Serial Number           : xxxxxxx
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:06.526: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.150: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.747: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.863: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.895:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.004: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.072: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.072: %SNMP-5-COLDSTART: SNMP agent on host AP001d.4536.86ca is undergoing a cold start
*Mar  1 00:00:12.154: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:12.369: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:13.016: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:20.493: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:00:30.976:  status of voice_diag_test from WLC is false
*Mar  1 00:00:31.083: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:34.263: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:34.304: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:34.342: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:35.265: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:35.265: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:35.304: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.tester.net"...domain server (10.10.10.40)
Translating "CISCO-LWAPP-CONTROLLER.tester.net"...domain server (10.10.10.40)
*Mar  1 00:00:42.131: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:42.135: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:00:42.139: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:01:32.143: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:01:34.274: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Not in Bound state.
*Mar  1 00:01:40.659: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:01:40.778: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:01:48.652: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:48.655: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:01:48.657: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:02:28.661: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:02:37.173: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:37.290: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxx.xxxx
*Mar  1 00:02:45.164: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:45.167: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:02:45.169: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:03:25.170: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:03:33.681: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:33.798: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:03:41.673: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:41.676: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:03:41.678: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:04:21.679: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:04:30.191: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:04:30.308: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:04:38.181: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:04:38.184: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:04:38.187: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:05:18.191: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:05:26.703: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:05:26.820: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:05:34.694: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:05:34.696: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:05:34.699: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROL
Thanks!!!
30 Replies 30
manassin
Beginner
Beginner
Hi Arika,
The AP is using the DNS option to join the WLC.
So in this case it seems that the AP is not able to join the WLC using dns.
Please run the following debugs on the WLC:
Controller>debug mac address
Controller>debug pm pki enable
Thanks and regards,
Manas Pratap Singh.
Recognize Your Peers
