AIR-LAP1252AG-A-K9 RED LIGHTS
mdrangell22
Hello
I have a issue with 2 AIR-LAP1252AG-A-K9, when I connect them to my network all the lights of Ethernet, Radio and Status turn on in red color and thry don't change, what could be happened? I have others AIR-LAP1252AG-A-K9 and works fine.
I tried CLI these 2 ap but nothing happen on screen.
Seb Rupik
Seb Rupik
Hi there,
According to the hardware guide:
Red
Red
Red
DRAM memory test failure.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1250/installation/guide/1250HIG_TD-Book-Wrapper/125h_c3.html#wp1077466
Cheers,
Seb.
Yes you were right .
Rasika Nayanajith
You can try holding reset button for 20+ seconds when powering it. Still not difference, I would think it needs RMAed
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
If all LED are red, then it's dead.
