AIR-LAP1262N-N-K9 & WLC CT5500
genesissales
My Light Weight APs 1262N-N-K9 APs are not being discovered by CT 5500 controller. I am using a Cisco Catalyst 2960 with PoE switch to connect Light Weight APs to Controller 5500.
Can I use the 5500 controller's internal management interface as DHCP server to assign IPs to APs?
Pls. help.
rgds
9 Replies 9
Rasika Nayanajith
Have you configured any WLC discovery methods ? Here are the 4 methods available
1. DHCP Option 43
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
2. DNS
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
3. Broadcast forwarding
http://mrncciew.com/2013/05/04/wlc-discovery-via-broadcast/
4. Static Configuration
http://mrncciew.com/2013/03/17/ap-registration/
You can configure internal DHCP server for this purpose (if you have small number of AP). You cannot use DHCP option 43 to discover WLC by your AP (so DNS method or Broadcast method to be used). Refer below for more detail
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/wlan/config_wlan_chapter_0100.html
Rasika
**** Pls rate all useful responses ****
Leo Laohoo
Kindly post the following outputs:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief; and
5.  AP:  sh inventory
Hi Leo,
Pls. find command outputs.
1.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.103.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... Cisco_WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.1.1.10
Last Reset....................................... Power on reset
System Up Time................................... 0 days 0 hrs 45 mins 19 secs
System Timezone Location.........................
Configured Country............................... IN  - India
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +33 C
--More-- or (q)uit
External Temperature............................. +18 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ A4:93:4C:FB:42:00
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 100
2. sh time -
(Cisco Controller) >show time
Time............................................. Thu Dec 26 17:41:59 2013
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
(Cisco Controller) >show interface ?
summary        Display a summary of the local interfaces.
detailed       Display detailed interface information.
group          Display a summary of the local interface groups.
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       1    untagged 10.1.1.10       Static  Yes    No
service-port                     N/A  N/A      192.168.1.2     Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
3. AP sh version
AP30f7.0dd8.c9ef#sh version
Cisco IOS Software, C1260 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 30-Apr-12 13:33 by prod_rel_team
ROM: Bootstrap program is C1260 boot loader
BOOTLDR: C1260 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA5, RELEASE SOFTWARE (fc1)
AP30f7.0dd8.c9ef uptime is 0 minutes
System returned to ROM by reload
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rc
*Mar  1 00:11:23.036: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960S-24PS-L (5897.1e75.af82)vk9w8-mx"
Last reload reason:
--More--                           agree to comply with applicable laws and regulations. If you are unable
--More--                           to comply with U.S. and local laws, return this product immediately.
--More--
--More--                           A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--                           http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
--More--
export@cisco.com.
cisco AIR-LAP1262N-N-K9    (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FGL1630S5XF
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from reload
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 30:F7:0D:D8:C9:EF
Part Number                          : 73-12175-06
PCA Assembly Number                  : 800-32268-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16304WJJ
Top Assembly Part Number             : 800-33866-02
Top Assembly Serial Number           : FGL1630S5XF
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1262N-N-K9
--More--                           Configuration register is 0xF
4. AP Sh ip interface brief
AP30f7.0dd8.c9ef#sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0           10.1.1.5        YES other  up                    up
AP30f7.0dd8.c9ef#
AP30f7.0dd8.c9ef#show inventory raw
AP30f7.0dd8.c9ef#
5. Sh inventory
did not give ay output.
rgds
Can the AP ping the management interface of the WLC?  If it can, then enter this command:  capwap ap controller ip address
AP30f7.0dd8.c9ef#ping 10.1.1.10
Sending 5, 100-byte ICMP Echos to 10.1.1.10, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Cool!  Now we are getting somewhere.
Is the WLC link to the switch a TRUNK?
What is the interface of the switchport to the AP?  Is it an access port?  If so, what is the VLAN?  Is the VLAN allowed?
I will reply once I a while as I am going to customer location. thanks for fast response.
rgds
Hi Leo,
while trying to configure CAPWAP ap ip it gives this message - You should configure Domain and Name Server from controller CLI/GUI.
rgds
Sure.  You need this information too.
