Air Magnet
ajuarez
Any recommendations on a new tablet for air magnet survey.
Justin Kurynny
Level 4
Level 4
Lenovo is running a special on the X220t. Upgrade it with an Intel Ultimate 6300-N in the customizer for 3SS surveys with the 3600. i5, multitouch, SSD, 3x3 antenna array in the display.
Justin
... typd on tny kybrd.
6 Replies 6
Leo Laohoo
George is not going to like this ...
Try Fluke Optiview XG
Justin Kurynny
Level 4
Level 4
Justin
I use the x220t, while it isn't as nice as the previous generations (I feel it's cheaply made and lacks the docking station additional battery charger) it is a good AirMagnet machine. Make sure you up the ram to 8GB as well.
I swear Leo is on the AirMagnet payroll ...
LOL!
George Stefanick
AM has a minimum requirement which is documented. Make sure its light and it can take an extended battery.
