AIR PCI340 Wireless Adapter drivers
Does anyone have Windows 7 64bit drivers for this type of wireless adapter:
AIR-PCI340
2.4 GHz 11 Mbs
Wireless Adapter
CISCO System
I would fully appreciate your help!
Scott Fella
This card doesn't support windows 7, the last support was windows XP. I wouldn't even use this card since it's very old and only supports 802.11b. Your better off buying a USB wireless adapter if you don't have an internal wireless NIC.
-Scott
