AIR-PCI352 external antenna
Hello.
I need to install a PCI wireless card on a PC, but I need to install the antenna 3 mt away from it.
How can I do this?
Can I use an AIR-CAB020LL-R (20 ft LOW LOSS CABLE ASSEMBLY W/RP-TNC CONNECTORS) to install the antenna remotely? And do I need an adapter to reconnect the same antenna, or do I need another one?
Thanks, Daniele
kmarrero
Level 4
Level 4
You can use the AIR-CAB020LL-R (20 ft LOW LOSS CABLE ASSEMBLY W/RP-TNC CONNECTORS to install the antenna remotely. You should not need an adapter for the antenna. You may want to use one of the antennas listed on the following URL as they may suit your needs better. http://www.cisco.com/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm
Thank you.
In the page that you have linked I've found only one antenna for clients (AIR-ANT3351), the others are for ap and bridges.
Do I need to use this one?
I want to use the one that is shipped with the card (I think that is AIR-ANT4941), can I use it?
