02-03-2019 06:04 AM - edited 07-05-2021 09:47 AM
I have some access points air-sap1602 and I would like to include them in other access points (air-ap1852) purchased now, is it possible? I'm not using any controller, it's just a few ap
Thank you
Solved! Go to Solution.
02-04-2019 06:12 AM
02-03-2019 07:52 AM
02-03-2019 08:14 AM
The 1602s will run under the 1852 in ME mode, dependent on the version of code being use.
Looks like the last version that was supported was 8.4.100.0
Under table 11 on this site is where i found this: https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-393660
02-03-2019 02:08 PM
02-03-2019 03:10 PM
02-03-2019 09:27 PM
02-03-2019 09:35 PM
02-03-2019 11:48 PM
No wont need to buy a controller or other hardware, just make sure the WLC version running on the ME AP supports the AP models you need/ want to support
02-04-2019 04:04 AM
02-04-2019 06:12 AM
02-07-2019 04:46 AM
so just pass this firmware ap1g2-k9w8-tar.153-3.JF.tar via web gui (http upgrade) and wait for mobility express to detect the ap ?
I can proceed with the upgrade!
02-07-2019 03:25 PM
I have a problem, mobility express sees the ap 1602 but does not join him and in the logs I find this error
%CONFIGSYNC-3-CONFIG_SYNC_SEM_REL_FAIL:.
%CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7076.
I have mobility express 8.5.131.0 (1852) and the subordinate ap has 15.5.3JF, if I have not read wrong it should be in the matrix
Help me!
I can return to autonomous ap ? i don't have access to cli with telnet/ssh!
02-07-2019 03:26 PM
Help me!
