AIR-SAP1602I-E-K9 can't display CLI after reset factory
lqnghia80
hi guy
i've reset factory AP 1602I and it couldn't dislay CLI.
console screen displays as below:
help me!
thanks all
Boot from flash
IOS Bootloader - Starting system.
FLASH CHIP: Micronix MX25L256_35F
Xmodem file system is available.
flashfs[0]: 182 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31936000
flashfs[0]: Bytes used: 10420736
flashfs[0]: Bytes available: 21515264
flashfs[0]: flashfs fsck took 10 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: fc:5b:39:b2:e4:53
************* loopback_mode = 0
button is pressed, wait for button to be released...
button pressed for 17 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/ap1g2-k9w7-mx.152-2.JB2/ap1g2-k9w7-mx.152-2.JB2"...#############################
File "flash:/ap1g2-k9w7-mx.152-2.JB2/ap1g2-k9w7-mx.152-2.JB2" uncompressed and installed, entry point: 0x100000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1600 Software (AP1G2-K9W7-M), Version 15.2(2)JB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 29-Jul-13 12:16 by prod_rel_team
Initializing flashfs...
flashfs[3]: 182 files, 7 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 31808000
flashfs[3]: Bytes used: 10420736
flashfs[3]: Bytes available: 21387264
flashfs[3]: flashfs fsck took 9 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio0  present 8764B 8000 0 A8000000 A8010000 0
Rate table has 180 entries (48 SGI/72 BF variants)
Radio1  present 8764B 8000 0 88000000 88010000 4
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP1602I-E-K9    (PowerPC) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FGL1839X1F4
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: FC:5B:39:B2:E4:53
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC1837279F
Top Assembly Part Number             : 800-38552-02
Top Assembly Serial Number           : FGL1839X1F4
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP1602I-E-K9
Press RETURN to get started!
*Mar  1 00:00:11.883: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:13.663: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:14.779: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:15.707: not a autoconfig enabled device!!!
*Mar  1 00:00:17.027: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:18.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:01:03.887: Starting Ethernet promiscuous mode
*Mar  1 00:01:03.959: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:01:03.959: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Mar  1 00:01:03.971: %SYS-5-RESTART: System restarted --
*Mar  1 00:01:03.971: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:01:04.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:04.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:04.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:01:15.927: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:01:16.927: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
Leo Laohoo
Check the configuration of the Console port.
5 Replies 5
Leo Laohoo
hi Leo
i setted as below:
baud rate: 9600
data bits: 8
parity:  None
stop bits: 1
How about Flow Control?  It should be OFF.
hi Leo
i haven't ping IP default of AP (10.0.0.1/24), too
my console cable is not unplug
hi Leo
