ā12-05-2012 02:58 PM - edited ā07-03-2021 11:10 PM
Hello I need help! I have the this controller AIR-WLC4402-25-K9 can I add the AP1232 to this controller?Is support this?
How can I do that?
Solved! Go to Solution.
ā12-05-2012 03:28 PM
It depends on what version of code you are running. So long as you are running 7.0 or older, that AP is supported.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
ā12-05-2012 03:40 PM
Hello Stephen, Thanks you for your reply.
