AireOS 8 - Network Lists for Split Tunneling
patrick.kofler
Hi all,
I just wanted to ask, if anybody could shed some light on this newly introduced feature seen in the screenshot?
What does it do? What are those lists bound to? etc.
I didn't find anything in the configuration guide. It sounds VPN related, because for OEAPs the split tunneling is done separately AFAIK. Could still be intertwined with each other though.
Patrick
Rasika Nayanajith
Hi Patrick,
It is looks like for OEAP ACLs. You can defined your corporate network subnets as part of network list & then you can recall them.
Below from page 828 of the WLC 8.0 Configuration Guide
From the Destination drop-down list, choose one of these options to specify the destination of the packets to which this ACL applies:
• Any—Any destination (This is the default value.)
• IP Address—A specific destination. If you choose this option, enter the IPaddress and netmask of the destination in the text boxes.
Network List—A specific network list. If you choose this option, enter the corporate subnets configured in the network list
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Hi Patrick,
Rasika
Hi Rasika,
thanks for the find. Hopefully there will be an update to include more detailed information on those lists.
Patrick
