Aironet 1231 problem with broadcasting 2 SSIDs.
forman102
I have several Aironet 1231 APs most running 12.3(8)JEA software. There are 4 SSIDs on (each in separate VLAN), with only one broadcasting (called pubwifi). The broadcasting one is an open, unencrypted network:
dot11 ssid pubwifi
   vlan 8
   authentication open
   guest-mode
After adding another braodcasting SSID (encrypted, separate VLAN), I encountered weird situation: my WiFi clients are unable to connect to pubwifi. It is not showing in the available networks or is showing as an "unknow" network. New encrypted/bradcasting ssid is advertaising just fine. Any ideas what's causing this?
Here's the new ssid config:
dot11 ssid newwifi
   vlan 14
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 106E243A
Of course, I also ran mbssid command on interface Dot11Radio0.
Thank you,
forman
6 Replies 6
Leo Laohoo
dot11 ssid newwifi
mbssid guest-mode
interface dot110
mbssid
Hey Leo,
I'm not sure how to interpret your answer?
Here's what I currentlly have configured:
dot11 ssid pubwifi                      ### existing broadcasting, open network
   vlan 8
   authentication open
   guest-mode
interface FastEthernet0.8
encapsulation dot1Q 8
no ip route-cache
bridge-group 8
bridge-group 8 input-address-list 700
bridge-group 8 output-address-list 700
no bridge-group 8 source-learning
bridge-group 8 spanning-disabled
New encrypted, broadcasting SSID config:
dot11 ssid newwifi
   vlan 14
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
interface FastEthernet0.14
encapsulation dot1Q 14
no ip route-cache
bridge-group 14
no bridge-group 14 source-learning
bridge-group 14 spanning-disabled
and config for:
mbssid                                 ### already enabled
Any other ideas? Right now, newwifi (encrypted) is broadcasting fine and is visible to wifi clients... but the original pubwifi (open) is being presented to the wifi  clients as "unknown" network and clients won't automatically connect to  it. Some clients don't even see its broadcast, so I need to connect them manually as to non-broadcasting SSID.
thanks
forman
This is what Leo means:
conf t
dot11 mbssid
dot11 ssid pubwifi
   vlan 8
   authentication open
   no guest-mode
   mbssid guest-mode
end
wr
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank you for clarifying this. As you can see, I have very limited knowledge of AP configs. Should I leave this as is?:
mbssid                 ### I added that command when I was originally setting the newwifi SSID, it was part of the                             ### Cisco doc
yes, that needs to be under the radio.
Steve
HTH,
Steve
Ok, after configuring:
dot11 mbssid
I didn't see mbssid in running config for interface Dot11Radio0 (which should be there), so I re-entered it, but to no avail:
sh run int dot11radio0
Building configuration...
Current configuration : 627 bytes
no ip address
no ip route-cache
encryption vlan 4 mode ciphers tkip
encryption vlan 14 mode ciphers tkip
ssid xxx
ssid xxx
ssid xxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no power client local
power client 50
power local cck 50
power local ofdm 30
channel 2462
station-role root
l2-filter bridge-group-acl
end
I assume that this is normal, so I'm out to test this config. Thank you both for help with this.
forman
