aironet 1310 using Peap Auth and AES encryption??
jalexan
I have 2 1310 wireless briges in a point to point configuration with the root bridge acting as my ACS server..
I am currently running Leap Authentication and with Wep encryption but would like to upgrade this to use Peap and AES if possible??
I'm wondering if anyone has upgraded their solution to this type of encryption?
thanks
What IOS version are you running ? 12.4(25d)JA is the last supported IOS version for this product. So you should go with that image.
If you are using AP as AAA server, then I think only EAP-FAST, LEAP & MAC authentication is supported. Not anything else.
Here is WGB (workgroup bridge) configuration with EAP-FAST & you can get an idea how to configure EAP-FAST if you choose to. (In your case you have to configure root bridge & non-root bridge in two respective AP)
http://mrncciew.com/2013/04/28/wgb-with-eap-fast/
Rasika
**** Pls rate all useful responses ****
Thanks Rasika,
i'm currently running c1310-k9w7-mx.123-8.JEA3
Abha Jha
Yes definetly with the upgrade of your IOS on 1310 you wil be getting the desired feature.
softwrae that needs to be upgraded :-
12.4.25d-JA2 IOS
